Results 1 to 4 of 4
Thread: Temp fluctuations
    david7307 Guest
    Temp fluctuations
    This morning while pulling the caravan I noticed my water temp fluctuate from normal to low ,water levels on header tank are ok and none used ,and motor running ok no miss firing
    I thought it may be thermostat playing up any info
    Back down the hill.
    Thermostat or sensor, mine does the same occasionally.
    Apr 2010
    South Melbourne
    If it’s a TD5, common cause is failing insulation where the wiring goes around the front of the head.
    Sep 2010
    The Hills.
    152.79 MB
    If it's the factory gauge, fit another. The factory one is useless, you cannot trust it.
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
