Results 1 to 10 of 16
Thread: D2 brake question
    Sep 2010
    The Hills.
    152.79 MB
    D2 brake question
    My d2 has, ever since I've had it, needed a quick pump on the brake pedal to bring the pedal up to get firm braking. It stops without this, but it feels 'off'. When a local indie did the head gasket I mentioned this, and he said it was normal, and his own car did it.
    It's not air. it feels like excessive disk brake runout, and I can't see it being "normal". I'd forgotten about it as the car has been off the road for years, but now it's time to get it roadworthy and I don't see it passing the check.
    My feeling is the wheel bearings are worn on the front, causing runout, but what does the brain's trust think? I believe that the wheel bearings are serviced as an assembly, and are of course not cheap. Car has done 310,000. Who knows if the PO changed them?
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    May 2015
    Williamstown, Victoria
    Mine was similar. I replaced the brake hoses with stainless steel braided, Teflon lined ones.
    Build date 11th Oct 2003
    LROCV #1410
    Sep 2010
    The Hills.
    152.79 MB
    Quote Originally Posted by Bohica View Post
    Did it work?
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    May 2015
    Yes, much better. Drop by if you are in the vicinity and have a drive.
    LROCV #1410
    Sep 2010
    The Hills.
    152.79 MB
    Lol, I was down that way yesterday...
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    May 2003
    On The Road
    I think the soft pedal is normal, they do stop better than the D1's that had a brick wall for a pedal.
    Jan 2017
    Geraldton WA
    How much "Meat" is left on your brake pads front and rear?
    4.6m Quintrex boat
    Avoca Beach
    FMine doesn’t do that.
    I pressure bleed and flush old fluid about every 2 years and exercise the hill descent every couple of months.
    I have some stainless hoses on order and have hopefully arrived when I get home next week, but even with 18 year old lines it is fine.
    I have new front discs, and front bearings but if the. Bearings are crook you will get ABS three amigos.
    My pads ar e also TRW so are soft and have plenty of meat.
    regards PhilipA
    Jan 2013
    WA
    Had the same problem with my TD5 and found that when i did the de EGR'd it created the brake pedal double pump low pedal issue. I blanked the main vacuum line at the take off, instead of at the solenoid, which corrected it
    Cheers tt
    D2 2004 TD5 Classic
    Jan 2011
    Gippsland
    D2 brake question
    D2 brakes are like that.... braided brake lines, regular fluid changes, manual bleed and then finish off with the workshop power bleed procedure, plus the absolute best quality disc pads that you can afford, and these will all contribute to diminish the problem to a point that you will be almost no longer aware of it D2 brake question
    LROCV member #131
    1999 build D2 TD5 Auto, Mantec snorkel, 2" LRA spring lift, ARB on board air, Ashcroft ATB, CMM air ram CDL shifter, swag & gold pans ....
