Results 1 to 10 of 24
Thread: My d2a towing coolant tempt
    Nov 2018
    Hi mates, I was using my Autel Pro scanner to read live coolant tempt in my D2a towing trip last week.
    Day trip, towing 1.2T trailer, about 28 degree ambient, Airconditioner on LOW with level 4, reading tempt in the range 70 - 77oC.
    Night trip, towing 3.5T, cool night about 20oC, Airconditioner at 18 on level 2, reading tempt in the range 70 - 82oC.
    High tempt related to a few times of using 3rd or 2nd gear up steep hills.
    Does this sound right?
    Perth WA 6149
    Sounds a bit on the cool side to me.
    Steve
    Jun 2013
    Universe A
    I second that, I'd be checking if the sender is faulty first, if that's ok then the thermostat.
    The sender can be checked against the one in the fpr.
    James
    Jul 2014
    west of Transylvania
    It doesnt sound right at all to me, the optimal running temp is around 88-90*C for a Td5, lower ECT readings would increase fuelling. Aircon has nothing to do with that, check the fuel temp reading too next time, it should be around 10-15*C lower than the ECT. Yur thermostat might be stuck open... and even then it's a bit low especially with trailer
    Avoca Beach
    My D2 TD5 EU3 auto nearly always runs at between 82 and 85 C at those temperatures of around 20C.. Measured with a dry sensor located next to the ECU sensor and calibration checked against the ECU sensor using a Nanocom. Largest difference was about 0.2C.
    Towing in 32C last week it ran at 85C on the flat and reached a max of 94 on a long climb at 115Kmh.
    The thermostat starts to open at 82c and is fully open at 88C.
    Mine has done this with an old thermostat and a new one .
    I would suggest that under 82C suggests a leak in the thermostat , however under cruise conditions 82C-85C up is acceptable.
    Regards PhilipA
    Nov 2018
    Here is the shot with 1.2T trailer alone, I stopped to take a photo asap so the tempt would not change.
    Jan 2017
    Geraldton WA
    Something seriously wrong with those readings especially the IAT reading of 67C for that to be accurate it would have to be 60C+ ambiant temp outside the car.
    4.6m Quintrex boat
    Jun 2013
    Universe A
    Quote Originally Posted by maxperformance View Post
    The IAT is fine, that's in the inlet manifold, looking at that display, if it's correct, I'd say your ECT sender is kaput.
    James
    Nov 2014
    Nirvana near Albany W.A.
    Quote Originally Posted by shack View Post
    James
    X2 , or the reader isn't reading correctly , it can't spell manifold either
    Sep 2010
    The Hills.
    152.79 MB
    Quote Originally Posted by discorevy View Post
    Perhaps it's dyslexic.
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
