Results 1 to 10 of 13
Thread: T/C interlock.
    Sep 2010
    The Hills.
    152.79 MB
    T/C interlock.
    RAVE isn't particularly helpful here, or I'm not reading it right. So, as I believe that there is no such thing as a silly question, I'm going to ask one. Can a badly adjusted XYZ allow all functions but still engage the T/C interlock? Car went into low range two days ago but refuses to do so now.
    Apologies. I'm still relearning the car.
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    99.87 MB
    I dont think anything interferes with the transfer case gear selection. But they do go into low range far easier when they're rolling just a little bit.
    Slunnie
    Apr 2012
    Whyalla, SA
    T/C interlock.
    Neither are related to one another.
    Are you trying to static move it? Or just rolling a little at the time?
    It will be an adjustment.
    Sep 2010
    The Hills.
    152.79 MB
    That's the issue. It went in fine, as it always did, so I know the shaft probably isn't seized, but there is an interlock function. I remember it from before. Park or neutral or no low range.. I had it in low the other day to use HDC to shake up the shuttle valves....
    Now the lever will not move.. I'll get there.
    RAVE is so LONG.. I found it today, now I can only find some bizarre Japanese reference.
    Guess I'm answering my own question. Adjust the XYZ correctly and see what's what.
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    Avoca Beach
    There is no interlock.
    The reason only P or N is that then there is no power through the gearbox which preloads the TC gears and stops range selection.
    The selection of high or low range is entirely mechanical through the shifter.
    Regards PhilipA
    Sep 2010
    The Hills.
    152.79 MB
    Regards PhilipA
    Personally I'd agree, but RAVE does not. An interlock solenoid exists. Whether it exists on my car is something I'll have to investigate, but my question pertained to why I cannot now engage either neutral or low range today when I could two days ago. I was never able to engage the T/C previously unless the car was in Park, and maybe ( memory is not perfect ) Neutral.
    I'll report back.
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    99.87 MB
    I'm pretty sure the only interlock is on the US delivered vehicles that doesn't allow you to take it out of P unless your foot is on the brake.
    Slunnie
    Apr 2012
    Whyalla, SA
    The High / Low selector is a simple mechanical lever and a push/pull cable connected to the stub on the TC.
    If it isn’t moving freely then it’s likely it needs lubrication or has something stuck at the TC end.
    Not uncommon if not used for some time.
    There are NO interlocks on AU versions.
    Sep 2010
    The Hills.
    152.79 MB
    Thanks everyone, I'll go back to the drawing board. It's nuts though, it's been working just fine and now it ain't. Just when I thought i'd spent enough time under the thing
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    Apr 2016
    Country Vic.
    try reversing a bit too.
    When I bought my D1 some years ago, previous owner (of 3 years) never used TC at all.
    On a side track, I pulled up, tried to select diff lock and low range. Diff lock eventually came on, but took a long time to get into low range.
    Eventually I reversed just a meter or so, back in neutral and it slotted in perfectly, under pressure on the lever of course.
    But like others have said .. just a teeny amount of motion, (in either direction) may help.
    Arthur.
    '03 D2 Td5 Auto
    '03 D2a Td5 Auto
