The power supply to interior lights including the glove box light are on a delayed “battery saver” timer.
 Super Moderator
						Super ModeratorI'm getting ready to install some fruit, and one of the things I'm going to do is the dash cam. Since I'm pulling bits off to run cables, along with others, I intend to run a 6 core up to the central light console above the drivers head with constant 12V and switched 12V for future fruit. I was wondering if anyone knew of a "delayed switch off" source of 12V in there somewhere that stays active until the car goes to sleep?
I'm just shooting this off to see if anyone knows off the top of their head before I sit down and bust out the wiring diagrams and a meter.
Just thought it'd be nice to let the dash cam run until the car goes to sleep.
 Super Moderator
						Super ModeratorGold. 10A fused on the battery saver relay and available all over the place. Thanks!
That allowed me to narrow 200 pages of wiring diagram down to 3. Much obliged.
We’re only talking a few seconds to minutes depending on battery charge state.
Better to put the dash cam on a LVC made for them.
 Super Moderator
						Super Moderator Super Moderator
						Super ModeratorOn the D3 there are two types of delays. One is on the overhead interior lights which powers down after a default 60 seconds (although this can be adjusted from 10 to 240s). These are unfused and controlled by the FET’s in the CJB.
The other is the power supply to the glove box lamp, map reading lights, and mirror vanity lights which power down after 15 mins. This relay is after the fuse so would have to pick up the power feed after the relay.
 Super Moderator
						Super ModeratorThe FET controllled outputs are dimmed, so they’re not suitable. The relay controlled output is available directly at the overhead lamp as its used for the side lights. My gut says 15 minutes is a bit long. I might just knock up a timer for a minute or two or just run it off an ignition feed. Decisions, decisions.
