Thread: Harsh down shift in sport mode... normal?
    Apr 2014
    Melb
    So when I’m in sport mode (not using paddle shift) then break hard, the downshifts are quite harsh. A bit violent sometimes. Just wondering if the experts know if this is a Land Rover thing, or is there a problem somewhere? also a tiny bit of play when taking off, and a tiny clunk going into reverse. Cheers blokes.
    2014, 8 speed, 1100ks.
    St Helena,Melbourne
    1.13 MB
    Quote Originally Posted by Spence View Post
    Has it had a fluid/filter change ?
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Apr 2014
    Melb
    Yes mate, at its last service.
    Sep 2014
    Baldivis WA
    How many kms on the car? Im assuming from your signature it's around 110,000km. You will need to reset the adaptations in the transmission to factory after a fluid change, the mechatronic adapts the solenoid opening and closing based on line pressure as the fluid ages and gets contaminated, the pressure changes.
    Worsy case the valve body is full of gunk (a flush doesnt get it all out), the accumulators and end seals in each valve line are probably worn, causing pressure fluctuations and harsh shifts.
    Check out the Sonnax website for more info. A valve body gen2 zip kit and new solenoids will solve it.
    Apr 2014
    Melb
    Quote Originally Posted by Eric SDV6SE View Post
    Excellent advice. I will look into it, as it annoys me good and proper.
    St Helena,Melbourne
    1.13 MB
    Are they readily available for the ZF8 ?
    1974 VW Kombi bus
    Apr 2014
    Melb
    Also,why would this only happen in sports mode?
    St Helena,Melbourne
    1.13 MB
    I believe it uses higher line pressures and holds the gears longer.
    1974 VW Kombi bus
    Apr 2014
    Melb
    Yep, makes sense.
    Sep 2014
    Baldivis WA
    Not sure if Sonnax has a zip kit for the 8spd yet, but the issues would be the same
