Added a EO Mini Pro. Max out at 7Kwh charge which is at least 3+ times faster than the wall plug item that came with my wife's car.
Like everything best laid plan getI measured the front of the garage and allowed a 5m cable to reach the front both sides of the double garage. My helpful sparky pointed to the back of the garage with a sub board and Yep. The cable is about 1m short for the job. Happily that can stay in my car and a slightly longer cable is on its way.
Sparky was a bit worried the 35amp line might be stretched if hot water heat pumps and the EV charger went on at the same time. He added AMP limiter set at 25 amps.
A little set up hassle had EO Tech support from the UK call and help me. A hour of laughs honestly late last night due to the time zones. The EO Mini Pro has a build in adjustable amp setting item in side. I was offered a 22Kwh 3 phase charger. Stupid me did not recall the sparky added three lines to the garage 4 years ago during a refit- Whoops
It all just works happily. Scheduled to late night or sunny day charging now.
					 Not mine yet I volunteered to add a wall charger to our Solar PV..... Tricky but Mr Finn Peacock ex CSRIO helped a lot
