Results 1 to 4 of 4
Thread: Reinstalling upper tailgate trim
    Feb 2009
    Reinstalling the upper tailgate trim is proving a challenge. Which is the best option - round, white clips (or 2 yellow to replace the broken white ones!) first or flat, blue clips first?
    thanks
    Apr 2012
    Whyalla, SA
    Line up the metal clips first.
    Then a firm thump to seat everything home.
    josh.huber Guest
    Like tombie says, the secret with trims is forget it's your car and how much you paid for it. That'll always get it done.
    Feb 2009
    Success. Turns out that a bit less ignorance is a handy companion to brute force.
    And while the screw inside the door handle will not grip, I am not taking the trim back off to explore the issue.
    Now, if only I could remember where I put the door striker rubber trim two weeks ago??
