Results 1 to 10 of 11
Thread: TD5 engine cranks over but wont fire up
    Feb 2021
    England
    Hi, My td5 engine cranks over but wont fire up, not even trying. Suspected the crank sensor but the engine ecu shows a rpm when cranking so I assume its OK. Rev counter is dead but I picked up on the following in the Rave.
    The tachometer, which is located to the left of the speedometer in the instrument pack, displays
    engine speed between 228 – 6,000 rev/min. Below 228 it receives diagnostic pulses only.
    If I don't turn the ignition off and keep trying cranking it will not start. However 1 cycle of the ignition switch on/off and it starts straight away. It seems as though something is been reset. I don't think its fuel because cycling the ignition switch wouldn't suddenly provide fuel pressure. The Pump primes up every time. What is been reset ? Thanks
    Sep 2010
    The Hills.
    152.79 MB
    Quote Originally Posted by ES4 View Post
    Three questions: does the MIL ( check engine ) light up? And when it starts after cycling the switch does it run normally? Do you have access to a Nanocom?
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    Feb 2021
    England
    Cranks but wont fire
    Hi, No MIL Light, Runs normally. Used Lynx Diagnostics no fault codes. Thanks
    Jun 2013
    Universe A
    But does the little red light at the bottom of the dash come on/flash etc?
    Feb 2021
    England
    Hi, Do you mean the immobiliser led, I believe if it had not received the correct code then it would not crank. the light does go out after unlocking with the fob.
    Jun 2013
    Universe A
    Yep.
    They'll definitely kick over though.
    I'd see if that light behavior changes between ignition cycles.
    Dodgy inertia switch could also be worth looking into.
    James
    Feb 2021
    England
    Hi, I unplugged the inertia switch and it still cranks as you said, but it sets the hazards away so I don't think its that. Red led for immobiliser pattern stays the same. I have always started it the same way ignition on and straight into crank. What I am doing now is turning the ignition on wait until the fuel pump times out (20s) and then cranking and it starts first time. It could be taking longer to pressurise the fuel system ?
    Jun 2013
    Universe A
    Ok, so when it does start does it run rough AT ALL ? Even a little bit?
    Nov 2007
    Townsville Nth Qld
    Years ago when i did my 2000 d2 injector washers, it would wind but not start. starter was winding over well. Long story short turned out battery was on the down side, plenty of omph to wind her over but not enough to kick in the ecu. Was at wits end so fitted new battery and away it went . Check your battery .
    Feb 2021
    England
    Hi, Engine sounds the same as its always done once its started, Battery is 3 years old and tests at 70%. i will order a replacement just to eliminate it. I might remove the fuel pump relay to allow the engine to crank but not start and look at this crank position sensor as I have read it can become corrupted by the starter motor inducing a field into it or the wiring. LR have screened the cable from the sensor to the ecu for a reason. I am still convinced it electrical but I may be wrong. Its difficult at the moment as it an intermittent fault, so I am trying to re-create it so I can get some testing done. I always find doing diagnostics better than just throwing parts at it. Fortunately I have access to a second vehicle so I am in position to do this.
