Results 1 to 10 of 13
Thread: New tyre, different tread pattern?
    May 2015
    Williamstown, Victoria
    I have rooted on of my M/T tyres. Is it ok to buy the same size tyre, with a different tread pattern?
    Build date 11th Oct 2003
    LROCV #1410
    99.87 MB
    You can, it's just not ideal for proper handling and it makes the diffs and centre diff work a bit but there isn't really much you can do about that. The rules just say that they need to be the same size and construction.
    Slunnie
    Brisbane,some of the time.
    Most reputable tyre shops don't like different tread pattens on same axle, even though they maybe the same size, type and construction.
    May 2015
    This will be the spare tyre. However... The tread on the photo is a mirror image of the tread on the tyre, this could be a photo issue.
    LROCV #1410
    Back down the hill.
    Stand the new tyre next to one of the (preferably deflated) existing tyres. Tyre sizes are nominal, varying in actual size between makes and even types of the same brand.
    99.87 MB
    Absolutely when they're selling you a set of tyres, but they will also replace a ruined tyre without replacing the set. It's just the nature of using the spare tyre.
    Slunnie
    May 2015
    Deflated ok! A radial split in the inner sidewall.The diameters are the same.
    LROCV #1410
    May 2015
    The tread is identical, size etc. identical. The only difference is the name on the side wall. And the price.
    LROCV #1410
    NSW far north coast
    This ^
    Tyre sizes can vary so much at times even between batches.
    The Dunlop Motorsport blokes used to run a stagger tape over every English made race Dunlop and sold them as matched pairs.
    They could vary by nearly 1" in diamater for a nominal size. This was their batch variation!! New tyre, different tread pattern?
    Interestingly Japanese made Dunlops were much, much tighter in production tolerances.
    Jan 2013
    WA
    Quote Originally Posted by rick130 View Post
    This ^
    Yes i remember those days.....all they had to do was get two things correct, make em black and make em round...they all got one right
    Cheers tt
    D2 2004 TD5 Classic
