Results 1 to 10 of 12
Thread: Time to replace rear brake Pads
    Nov 2013
    Wollongong
    OK 140,000 k's new rear pads and discs need replacements. I have the parts, TR spares are the go for OME parts at a fraction of the dealer cost. Dealer quote $1,300 supply and fit , I have the parts for $285.00 and dealer will fit for $360.00 which still seems high.
    I used to do my own replacement on my R50 , but getting older and lazy , but thought I'd ask if anyone has replaced rear disc and pads and if this is a straight forward job?
    Dec 2009
    Ranelagh, Tasmania
    Very easy to do but you need an IID tool or similar to back of the park brake.
    Fuji white RRS L494 AB Gone
    2023 Ford Ranga
    Dec 2011
    Bundeena
    Quote Originally Posted by Bails View Post
    Here ya go, you can do it without the diagnostic tool but you will need another tool instead to back out the pistons. I have seen some do it using a screwdriver and leverage.
    Sean
    Nov 2013
    Wollongong
    Good info I didn't know about the use of the key Fob for placing the car in Jacking Mode. Also the mode for the handbrake was useful, The wind back tool I would use is a G clamp.
    Looks easy as So I might save a few dollars and learn.
    Brisbane,some of the time.
    I am very surprised the dealer will fit supplied parts.
    Not many private mechanics will do it either for many reasons.
    Nov 2013
    Wollongong
    Yes they have done this before, I run EBC front pads as the OME are ****e ! In fact the car was still under warranty when the front Disc and pads were replaced.
    May 2003
    On The Road
    with apologies to Bails...
    Its happened enough times now for me to ask,
    Does the rear end do more work than the front?
    More than a couple of dealers have bragged about NEW discs/pads/tyres on the rear,,
    Nov 2013
    Wollongong
    Rear brakes are used in the models with dynamic control hence more use more wear.
    Dec 2011
    Bundeena
    It depends on how you drive. More aggressive driving will cause dynamic/stability programs to kick in more often. If you're not too crazy around the bends then rear pad wear is fine.
    Sean
    Yass NSW
    I did mine this afternoon, a couple of learning points:
    The EPB maintenance routine fails with error 9 if you have unplugged the caliper - I managed to do this twice, both on retraction and returning to service. I even put the wheel on the second time and had to remove it again.
    I needed to replace the sensor on the back and the mount for the plug was designed by someone very mean. Firstly there are two cables mounted on the plate with fir tree clips and the brake sensor is the back one. when you remove them they break.... Secondly the new cable mount is very difficult to insert back in the hole. I used a small screwdriver to push the fir tree clip in bit by bit. I also swapped the brake cable to the outside of the mounting plate for easier access next time.
    Once the park brake has been retracted the piston is very easy to push back. It would be easy to brake the plastic housing on the back of the caliper if you were too enthusiastic with a g clamp pushing the piston back.
    I used EBC ultimax - OEM replacement pads from Sparesbox
    Regards,
    Tote
