Results 1 to 10 of 14
Thread: Back in the fold with a 2011.5 AB
    Jan 2015
    ..the thing wont start when I was about to drive away... Seem like a flat battery, alternator etc
    I went through the sale anyways, ..got it started and I drove home without issue. Loved the 2hr drive to Sydney
    Things to do before I can think of going places:
    Newmostly for my peace of mind)
    - Alternator
    - Starter
    - Battery
    - Water Pump
    - Pully(s) + Belt
    Not sure:
    - To do the drain yet
    - Suspecting coolant loss due to usual oil cooler issue (this was done @113k), is this a service item now?
    Other:
    - Detail and rectify cosmetic issues
    - Apple Carplay
    Also where can I get a proper list of the build card? (BA359804)
    Thanks,
    pd
    Brisbane, Queensland
    Congrats, so early 4.4 diesel?
    L322 tdv8 poverty pack - wow
    Track Trailer ARN 200-117
    REMLR # 137
    Jan 2015
    Thank you!
    07.07.2011
    build TDV8
    Lets see how it goes
    pd
    Mar 2007
    Dazzler
    Was that the grey AB originally from Tamworth ?
    Battery/alternator could be from no longer trips to recharge properly, AGM'S don't like many small trips, trust me I know. Oil cooler should be good for at least 100k if replaced. Coolant leak could be small hose or cap on the coolant tank. Just look for the usual tell-tale signs.
    Great car, that 8 speed is magnificent, wish my 2010 AB had it
    Drive and enjoy
    Laurie
    NSW SW Slopes
    The alternators on the 4.4 are not known for early failures, unlike the 3.6 alternators.
    Jan 2015
    Quote Originally Posted by Laurie View Post
    Dazzler
    Drive and enjoy
    Laurie
    It is the one from Tamworth and it drives so very nicely. I will look for the leak etc, but generally It needs a good clean up etc.
    Jan 2015
    Thanks Graeme,
    Some failures on the ffrr? anyways it is s high milage car and dont want to get stranded far away from any thing if i can avoid it
    Also I think the starter has carbon buildup, repair or replace?
    NSW SW Slopes
    It appears that the starter motors can give trouble, mostly with the solenoid contacts IIRC and possibly due to inadequate wiring to power the solenoid.
    Jan 2015
    Update
    Wrong battery fitted! Cheap no name LA
    Swapped with a Varta G14 and so far so good.
    Mar 2012
    Armstrong Creek, Qld
    Hey, Dazzler, did you previously own an '05 Prado, by any chance or, perhaps there are two 'Dazzlers' in my little circle?
    'sit bonum tempora volvunt'
