Thread: So you want to build a Land Rover....
    Ireland
    Feb 2010
    Building by Landrover stopped so home built might be required for a little while Known about the chip shortage for several months now.
    Jaguar Land Rover to suspend output due to chip shortage - BBC News.
    Jaguar Land Rover (JLR) is shutting its two main car factories temporarily due to a shortage of computer chips.
    The difficulties at Britain's biggest carmaker echo similar problems at other manufacturers, including Ford, who have been hit by a global shortage of chips.
    JLR said there would be a "limited period" of closure at its Halewood and Castle Bromwich sites from Monday.
    Back down the hill.
    No I don't, who told you otherwise? I'm too busy rebuilding the one iI have.
    Jan 2010
    Quote Originally Posted by NavyDiver View Post
    Maybe they can go back to building the old Defender, as no chips required.
    2005 D3 TDV6 Present
    1999 D2 TD5 Gone
    The reason for the chip shortage is simply that a little over a year ago, faced with plunging sales figures, most car manufacturers worldwide cancelled their orders for specialised computer chips necessary for virtually all current vehicles.
    The chip manufacturers happily moved their production line capacity into making chips needed for the vast increase in "work from home". And are quite happily continuing to produce these as demand soared and continues strong.
    It does not help that some chips used in cars need "state of the art" facilities that operate in the extreme UV. There are only three of these facilities, one in S. Korea, one in Taiwan, and one USA. According to one report I have read, building another one is going to take tens of billions of dollars, and take several years - provided you can get an export permit for the machinery (USA and Canada only) and can persuade the necessary skilled staff to work for you.
    The problem is not just the actual making of the chips, but the fact that everything has to be clean beyond belief, and the fact that you need to use a number of chemicals that are very difficult find a supply, to handle safely, and to clean up after. Waste handling is a major problem.
    Or you can redesign your systems to use less advanced chips - probably even more expensive; there was a reason the advanced chips were used!
