Thread: HVAC zebra strips
    Jul 2016
    adelaide
    HVAC zebra strips
    Hi guys,
    Is anyone in AUS selling these climate control repair strips? The original UK supplier is away/out of stock, and the postage on the eBay offerings is hideous.
    thanks,
    Zebra strips?
    Jan 2016
    Netherlands
    I guess he means the rubber connector strip between the display and the PCB?
    -P
    PS I know of no supplier specifically for this unit, but it is a commonly used item so if you can find something with the same dimension you should be good. Also, you should also be able to shorten them if they are to long.
    Jul 2016
    adelaide
    Yep that’s the one - but they’re not original fitment, so I can’t measure up an old one, and I suppose there’d also be a potential issue with the pitch of the conductors
    HEVAC LCD Connector
    Douglas Park, NSW
    Zebra strips?
    You haven't heard of them either? I came across them a couple of weeks ago for the first time.
    I'm about to have 5 sent out.
    You haven't heard of them either? I came across them a couple of weeks ago for the first time. .
    And I’ve been an electronics tech for over 50 years.
    Jul 2016
    adelaide
    hi, where did you source yours?
