Easy enough to make up,use a 12S plug connected to terminal 3 and 4[neg and pos]on the car on the other end whatever you require Anderson/Ctek etc.
Hi all,
Have been charging battery with CTEK MXS10 directly to battery and have read that it can also be done through the rear 12S socket -
Charging through towing socket - DISCO3.CO.UK Knowledge Base
Tow electrics charger adapter for CTEK, Accumate, Optimate, SAE, NOCO etc - Futuranet Ltd - Shop
Google search comes up with Britpart DA1409 - Just a moment...
Questions - is anybody else doing this? and is this part (DA1409) available in Australia?
Many thanks in advance!
2016 Firenze Red Disco 4 TDV6
2018 Firenze Red Disco Sport
... plus many previous!
Very easy to make...
And a damn site cheaper than the Britpart solution...
Or convert the 12S to an Anderson plug.
2004 Jayco Freedom tin tent
1998 Triumph Daytona T595
1974 VW Kombi bus
1958 Holden FC special sedan
 Member
						Member
						Hi can anyone advise where to get a 12s plug
If searching on ebay "7 pin EU trailer plug" works - you can leave off the 12S
7 Pin EU Plug Trailer Truck Towing Electrics 12V Connector Adapter Trailer BDA | eBay
David
Everything is easy when someone else is doing it
MY14 SDV6 SE Corris Grey
Compomotive 18s : D697s : Traxide DBS : LLAMS : ARB compressor : IC-455
Rhino Platform : GOE compressor, Tx & front bash plates, deluxe sliders
 Master
						Master
						Plug from Ebay, as mentioned above, and this is what I made up. Works fine.
2012 L320 Range Rover Sport Fuji White
REMLR 012
No 5 Trailer ARN 177-295
2006 Disco 3, 4L V6 Petrol SE Deceased Feb 26 2023
SOLD Engineers Trailer - no id
SOLD RAAF 231194 Perentie 110 GS - SIR ANGUS
SOLD 4MP COY Series 3 FFR 30-209
 Master
						Master
						What amp is the 12s plug power rated at? And is it a dedicated circuit?
 Super Moderator
						Super Moderator| Search AULRO.com ONLY! | Search All the Web! |
