Results 1 to 4 of 4
Thread: Seized ACE filter cap on valve block
    Dec 2013
    Geelong
    I’m having a lot of trouble getting the filter cap off. I’m at the point where I’m ready to either weld a nut on or replace the valve block. Anyone had issues with welding a nut on? Or any other tips to remove please. I’ve tried heat, vice grips, monkey wrench. Next is hammer in a torx bit and pneumatic gun. Cheers
    Jul 2017
    Victoria
    Trying cutting an slot in it deep one and hitting it with an chisel
    Quote Originally Posted by Geetroit78 View Post
    03 D2a Manual Td5 Modified, Ashcroft lockers F&R, Ashcroft R380,Atb lt230, Ashcroft Rear axles, AS manual IC, AS exhuast manifold, AS Coolant bottle, 3inch exhaust, alive GTB550 VGT, billies 7100s, 3inch lift, 4inch staino snorkel, 35s beadlocked
    Apr 2010
    South Melbourne
    Safest option is to leave it alone rather than getting aggressive with the valve block.
    Ive never removed mine in 320,000 km. All I do is about ever 2 years change the ACE fluid by emptying the reservoir refilling, going for a drive and repeat 3 or so times.
    The old fluid is clean but darkened a little.
    Simon
    Apr 2019
    Coolgardie WA
    Thumbs up
    Try Loctite Freeze and Release- spray can- about $22 from Repco or such.
    Have used it on a tight TD5 sump plug with a tap from a cold chisel and hammer.
