Results 1 to 10 of 11
Thread: Camshaft removal tips from the veterans
    shayne86 Guest
    Hi all.
    Thinking my old girl MAY be in need of a new camshaft. 280,000kms on the clock, plenty of grunt off the line but runs out of breath once its moving.
    My question to the more experienced landy owners is
    1: can it be done in situ? Or this a full motor out affair?
    2: anything else worth doing while im that deep into the motor? Timing chain, water pump etc etc
    NSW far north coast
    TD5 or V8?
    shayne86 Guest
    Quote Originally Posted by rick130 View Post
    TD5 or V8?
    V8. 2004 model if that makes any difference
    May 2015
    Williamstown, Victoria
    What else could cause it to run out of breath?
    Build date 11th Oct 2003
    LROCV #1410
    With radiator and timing cover and gear removed the cam should just pull out. New cam, lifters needed - you need to take advice on whether cam bearings should be replaced - normally I wouldn't unless something obvious but you are hi kms. This engine can only take a single timng chain so is likely stretched a bit so new timing gear as well.
    shayne86 Guest
    Quote Originally Posted by Bohica View Post
    Lack of forced induction Camshaft removal tips from the veteransCamshaft removal tips from the veterans
    shayne86 Guest
    Quote Originally Posted by 101RRS View Post
    I was looking at full kits with cam, lifters, chain, sproket etc etc.
    Just wondering if there was any other hidden nasties to look out for while i was there.
    Depending on driving style - eg towing, torque etc consider an specialist cam with characteristics suited to your driving. However if you are happy with what you have just a standard cam. With timing cover off (at your km) consider a new oil pump, renew serp belt pully and tensioner bearings or just replace. Other than cam bearings in the block there is not much else.
    Also consider buying one of these
    https://www.amazon.com/Land-Rover-3-.../dp/1855205289
    Land Rover V8 Engine Discovery Defender New Workshop Manual Service Repair | eBay
    Avoca Beach
    In an RRC you can also just lift the aircon condenser with say a come along so that it clears the cam coming out.
    I do not know about a D2 , but hope it is possible to do it also, as it is a PITA to degas the aircon to remove the condenser and then recharge it.
    Regards PhilipA
    May 2015
    Quote Originally Posted by shayne86 View Post
    Add twin TD5 turbos?
    LROCV #1410
