Results 1 to 6 of 6
Thread: Are these two faults related - suspension (again)
    Jul 2017
    Cairns
    Hello everybody
    Been getting the 'pressure does not decrease' fault for a while and it occured to me these may be related. Any ideas?
    MY11 Disco 4 and the compressor was changed and software reconfigured 9 months ago
    Discovery 4 2014 Ipanema Sand SDV6 HSE
    Defender 110 2022 Fuji White D300 SE
    Discovery 4 2011 Fuji White SDV6 HSE - gone
    St Helena,Melbourne
    1.13 MB
    That is usually caused by a faulty exhaust valve and or blocked filters which a new compressor usually solves.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Mar 2016
    They are not related issues but as mentioned, a new compressor should have solved one of your issues, unless of course your system has a leak and the compressor is constantly drawing in air that’s wet and the desiccant that dries the air has failed prematurely.
    2007 Audi RS4 (B7)
    Have the same faults coming up on my RRS. I found a leaking airbag which I have replaced and so far no faults even though I know they are not related. Going to service the pump as soon as I get a kit,
    Adelaide - Torrens Park
    I wouldn't lose to much sleep over the invalid data fault. These things log heaps of communication error type faults.
    Jul 2017
    Cairns
    Update
    So just got the car back form Rova Range - have to say Jason and the team do a great job - turns out the recently fitted AMK compressor had a faulty exhaust valve, which Jason predicted it would have. Apparently quite common on some recent compressors. Mine was only 9 months old. $45 for a new valve.
