Results 1 to 10 of 16
Thread: Current Draw.
    Jan 2018
    Boonah Qld
    Current Draw.
    When at rest, key turned off what current draw do you get. Mine has .05 amps is this normal?. The battery is always flat if I don't use the car for a few days. Replaced the battery with the same result. If this is high then I guess I'll have to start pulling fuses.
    Aug 2010
    Sunbury, VIC
    A 50mA draw shouldn't flatten the battery than quickly - should get weeks or more at that. Is the battery ok - or did you mean .5 amps (500mA)?
    Jan 2018
    Boonah Qld
    Quote Originally Posted by Homestar View Post
    No definately 50mA. My old battery did the same and now a new battery. I am not sure what the various on board computers might do when left to there own devices. But that is all that I have ever measured. Perhaps I should try another meter. I have an analogue multi meter, perhaps it's time to drag that out. I have never been keen on digital meters so kept the old analogue meter for just an occasion like this.
    Apr 2012
    Whyalla, SA
    Current Draw.
    Are you locking it each time you leave it?
    Was it an SLS vehicle now on coils?
    Any USB ports etc fitted permanently (always on) in the vehicle?
    50mA is nothing.
    Sep 2010
    The Hills.
    152.79 MB
    Do the doors lock normally with the fob? Mine had a faulty receiver in the roof which drained the battery.
    Where are you measuring the amperage?
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    May 2015
    Williamstown, Victoria
    A 60 Ah battery will last for 500 days at 50mA per day.
    What else is on?
    Build date 11th Oct 2003
    LROCV #1410
    Jul 2014
    PERTH, WA
    0.05 A current draw
    0.05 Amp continuous draw amounts to 0.05 x 24 = 1.2 Ah per day.
    (There is no such thing as 50 mA per day, it is 50 mA continuously for a day.)
    This suggests that a 60 Ah battery should last for (60 / 1.2) = 50 days.
    It seems that something may be wrong with your current reading, or something else is happening.
    Quote Originally Posted by Robflocar View Post
    Queensland
    Hi Rob, how much drive time are you doing?
    Not using any vehicle much and doing lots of short drives, will have your battery slowly discharging itself and it will be sulphating pretty quickly.
    A heavily sulphate battery will hold far less capacity and this will lead to the battery self-discharging in a short time, regardless of how small a load may be.
    You may need to rejuvenate your battery with a battery charger.
    Jan 2018
    Boonah Qld
    50mA is nothing.
    has air bags but used to have coils. The Slab has been changed to show airbags. No USB ports. Not locked in the garage no.
    Jan 2018
    Boonah Qld
    It is true that some of my drive times are shortish. Down into town perhaps 3 km and back. I have to use a battery charger to get it started although it will jump start. I checked with the analogue meter and it is accurate and shows 55 mA. The volts according to Nanocom are 14.4 when the engine is running. The battery was reading only 8.6 volts when I tried to start it yesterday. Perhaps there is not many amps coming from the alternator. Guess that is the next check I'll have to see where that can be done and find a big enough amp meter. I guess these alternators put out a big amount of amps when required. The other thing is that while the battery is larger than most it doesn't fill the battery box there is still a couple of inches of space. I could fit an isolation switch and then reset the radio code and clock each time. But that doesn't fix the cause.
