Results 1 to 9 of 9
Thread: Wiper Blades
    Jul 2018
    Tahmoor NSW
    Wiper Blades
    G'day All
    Have been down to the local Repco store looking for new wiper blades, the half moon thicker ones that come with the hold down wing.
    I asked the dealer for the repco ones and I purchased them for my L322 2004 RR Vogue, went to fit them yesterday and no fit. Long story short my wiper arm has a single flat button the slides th the passenger side and the wiper blade falls off. There is no hook on the end of the wiper arm just a little cage and the wiper blade has a little hollow area that clips flat into the arm and them slide the rectangular button back to lock it in. All very easy to replace but can't find the new blades to fit.
    Any help would be greatly appreciated, thanks in advance
    Nov 2019
    Pretty sure these are the ones i got last time, but purchased from ebay.
    Bosch 3397005808 Set Of Wiper Blades 808
    05 L322 Range Rover | BMW M62 4.4 | Cairns Blue
    07 Lexus GS450h | 2GR-FSE Hybrid | Blue Onyx Pearl
    I bought mine a few months back from KLR Auto
    Jul 2018
    Tahmoor NSW
    These are the standard wiper blades, I was looking for the new ones that are a lot thicker and have aerodynamic fins.
    I can get the standard ones fitted and bought at Repco for $20.
    The ones I was looking at are Bosch aerotwin style 550mm are not long enough.
    Mar 2007
    After trying to get aeroblades here I purchased these ! Check your model number just to check.
    HQ Windscreen Wiper Blades Flat Aero ADA62-621 Twin fit Range Rover MK3 322 L332 | eBay
    Very happy with the product; just remember to remove the internal plastic clips on the wiper arm or they won't fit. 10 minute job start to finish, but I did spray the old retaining clips with WD40 before hand.
    Laurie
    Black Edition Guest
    Quote Originally Posted by Laurie View Post
    Laurie
    Thanks Laurie. I actually clicked on the link above and bought the blades.
    I have received them and removed the plastic clip on the wiper but it doesn't slip on the wiper on the car.
    Any pointers or installation video (I can't find on Youtube) as how to to fit this on?
    I have removed A... and do I have to remove B as well?
    Thanks!
    Black Edition Guest
    I realised my own mistake.
    Instead of removing the clip on the new wipers, I actually needed to remove the plastic clip that locks the old wipers on the wiper arm that is attached to the car. *facepalm*
    So after doing that, I still struggle to clip it on the wiper arm after removing the plastic clip....Not sure which end to push it in....
    Any tips would be helpful... thanks in advance....
    Mar 2007
    2010 TdV8 Autobiography, D2 Td5, RRC 4 Door VM/300Tdi, RRC 2 Door V8
    Black Edition Guest
    Laurie, you are a champ!! Thanks so much... I feel so dumb now... lol
