Results 1 to 10 of 18
Thread: Coolant- Topped up with wrong stuff.
    Jul 2012
    Perth- South of the River
    Hi All,
    Ive topped up with 500ml of Penrite Red coolant. Then I though I should think about a flush so I started searching about that and have found that I should be using Penrite's Blue coolant. Mental note to self: do the research before hand in future....
    Is the 500mls of red a problem?
    Gone 05 D3 ARB Front Kaymar Rear Winch E-Diff LRA Tank Dual Battery
    Current 2015 SDV6 SE. Tow Pro Mitch Hitch Llams C/motives 70ltr w/tank 2 x comp Traxide BMS-2 x Aux 150w Solar Uniden Engel ARB drawer F/Runner rack Light bar
    Maybe ask Penrite. Not being facetious as it’s definitely a question I couldn’t answer and I’d want advice from the experts.
    (My cars have all used glycol based (green) coolant.)
    St Helena,Melbourne
    1.13 MB
    Quote Originally Posted by Dagilmo View Post
    Hi All,
    If it was red OAT already in it then no problem.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Jul 2012
    Good idea. Thanks!
    Jul 2012
    I'm second owner and have had it two years, I doubt it's been changed. With the handbook saying Havolene XLC which is silicate free and the Penrite blue silicate free but the red not silicate free, I'm guessing he red is not compatible with the current coolant. Just not sure if 500mls in 10 odd ltrs is an issue.
    Dec 2009
    Baldivis WA
    If it makes you feel any better, factory intervals for coolant change is every 10 years/260,000Km. So yours would still be on factory coolant providing there has not been a major coolant system failure. Penrite also do not make a coolant that meets the required WSS M97B44-D spec. Nulon do though WSS-M97B44-D - Nulon Products Australia which is readily available at SCA. I actually replaced my coolant at 5 years along with the top coolant manifold which is prone to sudden failure.
    2014, MY14 Discovery TDV6, Fuji White (2018-Now)
    2003, Discovery 2a, Td5 Manual, Zambezi Silver (2012-2018)
    2007, Adventure Offroad Campers, Grand Tourer (2015-Now)
    Apr 2012
    Whyalla, SA
    Quote Originally Posted by kelvo View Post
    For the record - It’s just Dexcool
    And yes Penrite do - their blue coolant meets it.
    Sep 2014
    Baldivis WA
    2 years on penrite red 500,000km coolant, no issues. At the time of my research, this met the spec. Full flush with demin. water beforehand.
    I dont think 500mls matters, all youve done is upped the concentration by 5%. If its still original coolant, a system flush and new fluid is not a bad idea, esp. If youre thinking of changing out the coolant outlet.
    Jul 2013
    Mixing coolant types can possibly cause issues. The majority of coolants are glycol based anyway, its just the additive pack that's different between the different types. Best bet if your unsure what's in there is to top up with distilled water.
    Shane
    2005 D3 TDV6 loaded to the brim with 4 kids!
    http://www.aulro.com/afvb/members-rides/220914-too-many-defender-write-ups-here-time-d3.html
    Jul 2012
    Quote Originally Posted by shanegtr View Post
    Thanks Shane. I've contacted Penrite and they recommend not mixing different types and to use their universal top up product if unsure of what's in there. Obviously, distilled water is a good option also.
    Looks like I'm doing a flush in the next couple of days......
