Thread: This has never happened to my Patrol...
    May 2021
    Mackay
    Hello, I'm new here.
    Well, I purchased a used 99 TD5 in reasonable knick and have been joking about the reliability issues I'm likely to experience with friends and family. Picked it up this morning and this afternoon threw the missus and kids into it and took everyone for a spin. First through the streets, then onto the highway for a little bit, back onto the streets and then went to watch the full moon rising. Decided to take a wiz down a dirt and sand track along the beach on the way home. Noticed that the car seemed to be really digging into the sand and struggling a bit, so much so that I u-turned around a stretch I know to be softer than the rest because by this time it was dark and I didn't want to get stuck. Seemed a bit sluggish on the dirt track on the way back, but the track is so rough I stayed in second gear. As soon as we hit the blacktop, I could tell something was wrong. At first I thought we'd gotten a flat tyre, but it turned out the brakes were locked on, and they quickly locked on harder as I used them to pull over to the side of the road (I'd hardly used the brakes at all on the track). As in locked in so hard, I had to put the car into low range to get it to move, which it barely could. I tried to move the car to a more convenient spot, but the brakes quickly started cooking so we pulled over pronto. Fortunately, being a Landy and kind of knowing what to expect, I'd thrown my toolbox into the back. As I sat there being pestered by the kids whilst laughing maniacally at my predictions coming true I managed to Google the symptoms and tried two suggestions. First suggestion pulling the ABS fuse didn't do anything but the second involving undoing the bleed valve on the rear brakes to release pressure did have some effect in that we were able to drive a couple of km's before the brakes locked up again so I had to rinse and repeat our way home, which wasn't too far away but nevertheless the brakes smelt like a train's by the time we got home.
    Now I can't blame the guy I purchased it off as he had mentioned it has had extensive brake work done. He gave me receipts for just about everything he's ever had done to it and sure enough all the brake calipers had been rebuilt and new pads installed with it having driven less than 50 km's or so and it's also got a new master cylinder fitted. The car has sat pretty much unused for the last 6 months, but gave no hint of trouble until we hit the track.
    That's the background out of the way. Now to try and figure out what it is. Obviously there has been an issue with the brakes previously and I'll need to ask the PO what the issues were. The crux of the problem is something is preventing the pressure releasing from all four calipers and logic would say it's a dud master cylinder but my knowledge of how the traction control and ABS works could be written on a pin head so perhaps there's some techno-gadgetry there that the problem. I've heard brake hoses can also cause something similar, but never on 4 wheels simultaneously I would think? So with this out of the way, I'm keen to hear thoughts and opinions on likely suspects for the cause of this problem??? Thanks!
    Sep 2010
    The Hills.
    152.79 MB
    Educated guess here.
    Had this happen on a non LR years ago. Pulled up at a level crossing and that was that, no moving it until I cracked a brake pipe union to release pressure. In my case it was eventually diagnosed as a blocked compensating port in the MC. This car did not have ABS though. But that or something similar would be my first port of call. Maybe when all that work was done some dirt or other contaminant was allowed into the system. If you have access to a Nanocom then I'd suggest a complete flush of the system. or take it back to the shop that did the work.
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    I’d check that the brake hoses haven’t swollen AND that if the master has been rebuilt it’s been done right. Had it happen on a Range Rover and a rebuilt master was at fault.
    May 2021
    Mackay
    Thanks guys.
    I've had a chance to get a bit more into it since my original post. The PO has a new master cylinder coming because the existing one was only recently purchased and installed. However, cracking the unions open at the master cylinder does not release the pressure off the brakes. This morning, I stuck the front axle on jack stands then cracked the bleeder on a caliper and got the wheel to release with some remaining drag (more on that below). The other side's brake remained locked. cracking the unions on the respective outlets of the ABS modulator released the frozen brake. This kind of eliminates dud hoses (I think?) and I'm now a little concerned that somehow the ABS modulator has something to do with this, but searching this Internet thingy (probably poorly) hasn't produced any hits of similar problems.
    As to why the brakes still drag, this has kind of been resolved. The PO had the calipers overhauled off the car and he refitted them with new pads but hadn't serviced the slider pins. I've only done the front so far but they were horribly gummed up with what looked like the remains of old bearing grease and dirt and one was seized pretty solidly and took a bit of effort to extract for cleaning. I've sorted that out and expect to find similar situation with the rear brakes when I go over them tomorrow. I doubt dragging due to gummed up or even seized slider pins would be causing this problem as a whole, but who knows?
    Apr 2012
    Whyalla, SA
    Sounds like the cartridges in the ABS unit are seized also.
    Get a Nanocom and cycle the shuttle valves and see if you get any joy.
    My bet is neglect has resulted in the cartridge valves sticking, or the system gummed up, as well as your noted neglect of the pins.
    May 2021
    Mackay
    I had a think about this over lunch and I'm reasonably confident I've worked out this little mystery.
    I reckon the PO has accidentally topped up the brake fluid with power steering fluid or similar a little while back. They'd then replaced the master cylinder and overhauled the calipers and given the system a flush to fix their snafu, but the ABS modulator has suffered swelling seals and I think when the TC has activated (I assume) while driving on sand the swollen seals have caused the valves that let fluid return from the calipers to the master cylinder to jam closed. So closed that the pressure never releases from the calipers.
    How does that sound for a theory?
    Sep 2010
    The Hills.
    152.79 MB
    ABS modulator aside ( very likely culprit ), sticking slider pins play havoc with brake, ABS, TC and HDC performance.
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    May 2021
    Mackay
    $$$$$ I seen some mention of group buys and discounts. Are they still a thing?
    May 2021
    Mackay
    Quote Originally Posted by Tins View Post
    I've grabbed a used one off eBay for a decent price (I'm guessing I can swap over the old one's electrics if the replacement starts lighting up the dash like a christmas tree). The PO said he'd replaced all of the brake gear because of a sticking caliper yet failed to clean and grease or even inspect the sliders. Cool story, Bro, lol.
    Sep 2010
    The Hills.
    152.79 MB
    Quote Originally Posted by reefmagnet View Post
    Absolutely. You can start a group buy yourself. Colin from BlackBox keeps an eye out for them. You just need to get the numbers.
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
