Results 1 to 10 of 13
Thread: How do you rate TD5 D2 as a towing machine?
    Mar 2011
    Balbarrup WA
    I have to take a 5000k round trip to Kimberleys towing an empty trailer up (1200kg) and likely it will weigh 3000kg loaded on return trip.
    Car is AUTO and is in good mechanical, 200,000k only, and is remapped.
    Should I have any concerns about its ability to tow the load on return trip, and does anybody know if it is likely to get into 4th (top) towing? or will it likely be happier to stay in 3rd?
    I'd be happy to tonk along at 80kph if that isn't being too optomistic.
    (I am figuring the D2 is easier to get repaired in an emergency in that remote region.)
    Apr 2012
    Whyalla, SA
    Does it have electric brakes?
    If so should be fine.
    Mar 2015
    Horsham Victoria
    The TD5 is a great tow machine in my opinion, we tow our 22ft van with ours I hold it back in 3 rd up inclines etc and slot it into 4 th on down hills or tail wind .
    Rob
    Mar 2011
    Balbarrup WA
    RE: Electric brakes
    Yes, trailer has electric brakes (on all 6 discs).
    Mar 2011
    Balbarrup WA
    RE: holding in 3rd.
    Quote Originally Posted by RobMichelle View Post
    Rob
    Will be happy to hold in 3rd for hills/inclines.
    Was just wondering if it can actually tow in top gear.
    Sounds like they can , at least on downhill and tailwinds, so should be OK, as long as I am happy to proceed at moderate speed the rest of the way.
    Vehicle has had a very sheltered life, nil towing, never worked hard.
    Jan 2017
    Geraldton WA
    It would pay to have the transmission serviced prior to your trip, Getting ANY sort of help with a landrover product North of Geraldton and especially in the Kimberly is very call tough indeed.
    4.6m Quintrex boat
    Oct 2011
    Fremantle WA
    Quote Originally Posted by vbrab View Post
    I always left mine in 3rd and sports mode when towing anything over 2 tonnes. Only time in D was downhill.
    From what I've been told your transmission will thank you for it, and fuel economy should be about the same as if you tried to stay in 4th - remembering that 4th lockup doesn't happen until 80 kmph.
    Mar 2011
    Balbarrup WA
    RE: holding in 3rd for towing
    Quote Originally Posted by gavinwibrow View Post
    I have noticed that since the remap, the D2 will not drop into 4th until I get well above 80kph and then push it to nearer 90+ (over 2500rpm at least), then it will go into 4th.
    Car seems happy to loll along in 3rd, and I expect that towing it will likley be happy to hang about at 80kph.
    All I want from it is for it to complete the trip without any big issues.
    Mar 2011
    Balbarrup WA
    getting trans serviced.
    Quote Originally Posted by trout1105 View Post
    Did trans service 5000k ago, along all new hoses, viscous bearing, pwr steering and water pump, manifold gasget, all pulleys, idlers, belt ect and recon of transfer box to deal with oil leak, so I am hoping the main organs (mtr/box), do what they are intended to do without any issues. I am taking a crate of service spares, but I do not want to be working on anything really.
    I'm taking the D2 because I am likely to be the one fixing any issues; as noted there is NOTHING past between Geraldton and Darwin that can help with Land Rover.
    "Murphy" was a bigger optimist than I am.
    Jun 2013
    Universe A
    3 tonnes is a fair bit behind a d2, would definitely be coming back to 3rd if it were me, but not in sport mode as it is more likely to drop out of lockup if you do.
    That's a bit unusual that it goes into lockup later now after a remap, there is really only a couple of reasons that would happen, and most tuners don't mess with it.
