Results 1 to 8 of 8
Thread: Buying a Discovery 4
    gbren Guest
    Hey Guys,
    I'm thinking about selling my ute and moving to disc and am looking for info/advice on whether i should be avoiding some of the available cars im looking at...
    Would you guys be able to have a quick look at both of these below and let me know your thoughts?
    Thank you
    carsales.com.au
    carsales.com.au
    Jun 2021
    Service history is critical on vehicles with higher mileage. Need to understand fully what has been replaced. Very difficult for forum members to make this sort of assesment. You need to check out and drive each vehicle and check the functioning of all the features.
    Nov 2015
    Black Rock
    Quote Originally Posted by Netorius View Post
    Service history is critical on vehicles with higher mileage. Need to understand fully what has been replaced. Very difficult for forum members to make this sort of assessment. You need to check out and drive each vehicle and check the functioning of all the features.
    Agree. And don't listen to anything the seller of the red one says. The TDV6 doesn't have a timing chain (it has a timing belt and a rear belt which also needs to be replaced, along with other bits and pieces). Look at the documentation and check on who did the work. When you find a car you like, make sure you pay for a Landrover Indy to do an assessment. There's heaps that needs to be checked, from error codes to gearbox and diff oil, brake fluid changes etc.
    2013 D4 expedition equipped
    1966 Army workshop trailer
    Sep 2014
    Baldivis WA
    Quote Originally Posted by DieselLSE View Post
    Engine is a dohc multi valve V6. They run timing chains from outer cams to inner cams at the rear of the engine. The outer cams are driven via a toothed belt on the front of the engine, sitting behind the accessory multi v groove belt. Timing chain tensioners sit at the back of the heads, underneath the chains, in between the camshafts. When these guides wear, the engine develops a pronounced chatter at start up as it takes a bit more oil pressure to get the tension right. Tell tale for worn out tensioners and chains is to listen for the rattle, and if it goes for longer than 5 'skippy the bush kangaroos' be prepared to spend money to replace both tensioners or walk away. Having said that, talking to my indie, its not a common replacement, but as these cars are getting to 10yo plus, more and more will need timing chains and tensioners done. Im at 211,000km and no long rattle yet, all still in the green zone.
    gbren Guest
    Yes I will be giving the cars a very good look over. One of them has had the steel pan conversion on the transmission so I’m going to assume that it was also serviced but I will be asking and checking.
    Anyone recommend any Land Rover specialists in Sydney?
    St Helena,Melbourne
    4.28 MB
    Quote Originally Posted by Eric SDV6SE View Post
    Slight correction, chain is at rear of RH head and at the front on LH head.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Oct 2013
    Old Toongabbie, Sydney NSW
    Quote Originally Posted by gbren View Post
    I use Davis Performance Landys in South Windsor.
    Another often mentioned here is Graeme Cooper in St. Peters
    Martin
    Mar 2018
    Quote Originally Posted by letherm View Post
    Martin
    I am using Cremorne Prestige in Artarmon. Have been very pleased with their service and knowledge of LR issues.
    Mike
