Thread: push start 2002 disco 2
    Mar 2019
    Oberon
    Just wondering if you can push start an automatic discovery 2. car wont start doesnt seem to wind over at all... just want to see if the car can start with a push just dont know because its an auto if it can be done
    Ferntree Gully, Vic
    Not with an auto..
    Mandurah WA
    Probably bad contacts in the starter solenoid.....well known fault.For Land Rover Discovery Defender TD5 2.5 Diesel Starter Motor Repair Fix Kit AU | eBay
    May be lucky,try shorting starter main lead to the solenoid spade terminal!
    Apr 2016
    Country Vic.
    .... or the the spade connector off the side of the starter could be loose or dirty, and just touching it may get a better contact and you get starter action again.
    Arthur.
    '03 D2 Td5 Auto
    '03 D2a Td5 Auto
    Quote Originally Posted by SPROVER View Post
    Not with an auto..
    Unless there is a rear oil pump. I used to be able to push start my '56 Jag auto, it had a rear oil pump driven by the output shaft. Get the speed up to a few mph and there was enough oil pressure to operate the auto trans.
    Back down the hill.
    Same as Hydramatics.
    May 2009
    Tatura, Vic
    And Torqueflights. I could tow start my old S series Valiant that I had some 47 years ago.
    Wish I still had it
    Dave.
    I was asked " Is it ignorance or apathy?" I replied "I don't know and I don't care."
    1983 RR gone (wish I kept it)
    1996 TDI ES.
    2003 TD5 HSE
    1987 Isuzu County
    May 2015
    Williamstown, Victoria
    There is an episode or is it the film of I Love Lucy, where a car won't start and the driver says you have to push it up to 30 mph so that the auto can start the engine. Lucy then proceeds to drive her car with the intent of hitting the other one at 30 mph!
    Build date 11th Oct 2003
    LROCV #1410
    Jan 2010
    One pro'ly wouldn't be able to push start a D2 auto, but you might be able to tow start it, the aforementioned 30mph or 50kmh sounds about right as a minimum for high range, or maybe push start it down a steep hill in low range. I'm only saying this as I have tried the steep hill trick on my D3, never gave it a try in my D2.
    2005 D3 TDV6 Present
    1999 D2 TD5 Gone
    May 2009
    Tatura, Vic
    Quote Originally Posted by RANDLOVER View Post
    You can tow it to 100 and it still wont start. As has been stated, if the auto does not have a rear pump it is impossible.
    And ZF's don't have one. The auto's that do, the pump is driven off the output shaft.
    When sufficient speed is achieved, around 50 kph, enough pressure is generated to allow the clutch plates to engage and the torque convertor to spin the engine.
    Dave.
    1996 TDI ES.
    2003 TD5 HSE
    1987 Isuzu County
