Results 1 to 10 of 35
Thread: Changes to vehicle testing regime...over here not over there.
    Ireland
    This won't impact any of you antipodeans but it is to come into effect over here. The test is very strict as it is. This is just something else that is being added to the pass/fail regime.
    In an effort to meet Ireland’s strategic objectives and continue to lead the way in improving road safety through the use of vehicle technology. Ireland in accordance with EU Directive 2014/45, will commence the use of OBD testing as part of the National Car Test (NCT) from 21st June 2021.
    Ireland will be one of the first of the EU Member states to implement this new approach of testing which will help contribute to significantly safer vehicles on Irish roads.
    The following changes will come into effect in the NCT from the 21st June 2021.
    NCT Manual 2021
    From this date, a new version of the NCT manual V5.0 (June 2021) will come into operation. The NCT manual lists each item on which a car will be tested. It lays down the test method and pass/fail criteria to be adopted for the compulsory road-worthiness testing of passenger vehicles. It provides guidance in relation to why a vehicle may fail the NCT and the categorisation of defects.
    The new manual is updated in line with Directive 2014/45 (EU) and is available for download on the NCTS website (Home) and Road Safety Authority website (RSA.ie - Home)
    OBD Testing
    An On-Board Diagnostics System (OBD) is a computer system inside a vehicle, that tracks and regulates a car's performance. It collects information from sensors inside the vehicle, to alert the user to a problem, often before it becomes a major issue.
    From the 21st June, OBD testing will become an inspection item in the NCT. It will be introduced on a phased basis. Initially, when an OBD error code is detected it will result in the vehicle receiving an “Advisory Pass”. Then, from early 2022, when an error code is detected, this may constitute a reason for “failure”.
    The inspection is quick and easy, the NCT Vehicle Inspector will plug the OBD scanner into the vehicle's OBD computer port known as the DLC (data link connector). This port is usually located under the steering wheel but may also be found in the glove compartment of the vehicle.
    This OBD scanner will quickly indicate whether or not error codes exist, and it also helps and alerts the Vehicle Inspector to possible defects within the vehicle.
    In order for the NCTS to conduct the inspection, we ask customers to ensure:
    Their glove compartments are unlocked and clear of personal belongings before their NCT.
    That any devices using the OBD port in the vehicle are removed in advance of the NCT.
    The OBD scanner will scan the OBD system for:
    Vehicle Identification Number (VIN)
    Using the OBD scanner, the Vehicle Inspector will verify that the VIN read by the OBD scanner matches the number on the vehicle. While a difference will not be a reason for failure, the OBD VIN reading will be recorded on the VIR (Vehicle Inspection Report) issued to the customer.
    Odometer Reading
    The Vehicle Inspector will record the odometer reading at the time of the test. They will also verify the reading using the OBD scanner and customers will be alerted to both readings on their VIR report.
    Electronic Braking System (EBS)
    Any error code associated with the electronic braking system will be recorded on the Vehicle Inspection Report (VIR) provided to the customer following their NCT inspection.
    Anti-lock Braking System (ABS)
    Any error code associated with the antilock braking system will be recorded on the Vehicle Inspection Report (VIR) provided to the customer following their NCT inspection.
    While, initially, vehicles with error codes will be recorded as ‘Advisory Pass’, the NCTS strongly recommends that any error codes be addressed by the vehicle repairer. However, the vehicle will not need to return for re-inspection, for these items alone.
    From early 2022, should certain error codes be detected, they will constitute a reason for failure in the NCT and an NCT certificate will not be issued until the items are rectified and a pass result is achieved.
    We recommend you liaise with your local garage/ mechanic who should be equipped with the necessary diagnostic equipment to perform this scan in advance of going for an NCT.
    Escalation of Defects
    The new NCT manual identifies that, where a combination of deficiencies is recorded in the NCT in one area of a vehicle, the combination of deficiencies could lead to the result of the NCT being escalated to ‘fail dangerous’.
    An example of one such combination is the inspection item, Brake Pedal. If the following 3 major defects appear on the overall test result, the result will be escalated to fail dangerous:
    Pedal travel is excessive, obstructed or insufficient reserve travel.
    Brake control not releasing correctly.
    Travel in the brake pedal indicates air in the brake system or brakes are in need of adjustment
    In such instances, the deficiencies are considered to constitute a direct or immediate risk to road safety and the vehicle should not be driven on the road under any circumstances, in accordance with The Road Traffic (National Car Test) Regulations 2017, S.I. 415 of 2017.
    For more information on these changes please see our FAQ
    For further information on the items inspected in the NCT, please refer to the NCT Manual
    Mar 2015
    Horsham Victoria
    Jeepers, the 3 omigos sudden appearance will cause a lot of headaches for d2’s over there.
    Back down the hill.
    Quote Originally Posted by RobMichelle View Post
    With Europe's fondness of chucking salt all over the roads, in winter, they've probably all rusted away.
    Jan 2010
    IIRC unlike D1's where the whole chassis rusts away, D2's are prone to rust only on the rear 1/4 of the chassis.
    2005 D3 TDV6 Present
    1999 D2 TD5 Gone
    Kallangur, Brisbane
    "Oh & we see via the OBD that you have been speeding on various occasions. Here are the fines & we get to keep your vehicle thank you."
    BIG DADDY is watching!
    Just wait till the info is uploaded automatically via your own home wifi or mobile data & the fines are emailed to you.
    + 2016 D4 TDV6
    Mar 2015
    Horsham Victoria
    Quote Originally Posted by Milton477 View Post
    Just like epa fines on a loud Harley just get em in the mail.
    Oct 2008
    Cloncurry NWQ
    How often does the Land of the Leprechaun have vehicle inspections?
    It has always intrigued me that Aus has such differing rules for this between States.
    In QLD you only need a pretty basic inspection when selling the car but I think some States have an annual inspection.
    In the Gulf Country there are some pretty doggy cars & trucks driving about.
    Jonesfam
    How do they do the OBD tests on cars with no computers? Neither of my Landrovers have computers! (2a and 110)
    When do Harleys get fines for excessive noise? Not often enough!
    Brisbane,some of the time.
    So I wonder if it picks up if the vehicle is tuned?
    And EGR’s are blanked?
    I bet it does 😩
