Results 1 to 4 of 4
Thread: Removing rear caliper. Remove ABS fuse relay?
    Mar 2011
    Balbarrup WA
    In remote area with stuck rear caliper piston.
    Only option appears to be remove rear caliper and clamp hose (done). Should I also remove ABS relay from under bonnet to prevent ABS trying to compensate??
    3000+k's from.Perth and 1600k's to where I can receive an express caliper.
    May 2015
    Williamstown, Victoria
    I think ABS on three wheels is better than no ABS.
    Build date 11th Oct 2003
    LROCV #1410
    Feb 2020
    Perth. Western Australia
    My understanding is that the ABS will only activate when braking, if the wheel (sensor) stops turning. That's not going to happen
    if caliper removed.
    You should be ok,
    I had similar situation many years ago up north, 200 plus kilometers from nearest town. rear caliper seized.
    First concern was overheating and warping the disk.
    It was a D1 with no ABS, I forced pistons and pads away from disk with crowbar. (Hey, stuck in the bush 40 deg heat)
    Then simply opened the brake bleeds on the rear and pumped the fluid out, so no rear brakes at all.
    The front and back are on separate circuits, so I drove VERY carefully to town with only front.
    NOT recommended if your towing.
    surprisingly, I didn't notice any difference to the braking. Obviously, as I found later, both rear calipers were not functioning correctly anyway, and replaced.
    I didn't think back then to just remove the caliper, lock the pads with some wood or whatever, as I didn't have a clamp anyway.
    As said, 3 brakes are better than none.
    May 2009
    Tatura, Vic
    Just try it and see what happens.
    If you have issues then remove relay.
    I think you will find it ok though, with relay left in.
    Dave.
    I was asked " Is it ignorance or apathy?" I replied "I don't know and I don't care."
    1983 RR gone (wish I kept it)
    1996 TDI ES.
    2003 TD5 HSE
    1987 Isuzu County
