Results 1 to 10 of 16
Thread: Blanking Oil Cooler
    May 2009
    Tatura, Vic
    Blanking Oil Cooler
    I have removed the EGR and now wish to rid the EGR cooler. I would also like to remove any unnecessary pipework.
    I know there has been plenty of discussion about blanking off the oil cooler outlet. I have had an extensive search and can't seem to come up with anything conclusive.
    Has this mod been proven to be ok. I know that the pipe from oil cooler is for EGR cooler, but was wondering does this also aide oil cooling.
    On the pre EU3 models the pipe just runs to the bottom of radiator. If removing and blanking the cooler outlet is ok, why did LR run this hose to bottom of radiator in the first place?
    Dave.
    I was asked " Is it ignorance or apathy?" I replied "I don't know and I don't care."
    1983 RR gone (wish I kept it)
    1996 TDI ES.
    2003 TD5 HSE
    1987 Isuzu County
    Jan 2011
    Gippsland
    Blanking Oil Cooler
    As I understand it, originally the radiator was partitioned so there was a separate tank at the bottom of the radiator for the fuel cooler circuit. LR later changed that to “improve the durability” of the radiator. The current spec rad has the oil cooler connection at the bottom of the rad blanked off which effectively creates a “dead link”. A search of my past posts will find the related Tech Bulletin.
    LROCV member #131
    1999 build D2 TD5 Auto, Mantec snorkel, 2" LRA spring lift, ARB on board air, Ashcroft ATB, CMM air ram CDL shifter, swag & gold pans ....
    May 2015
    Williamstown, Victoria
    I have a spare blanking cap. Mackay pn BC19
    Yours for postage. PM for details.
    Build date 11th Oct 2003
    LROCV #1410
    NSW far north coast
    As for it being ok, the last of the D2's came with the outlet blanked from the factory. Blanking Oil Cooler
    May 2009
    Tatura, Vic
    Quote Originally Posted by Bohica View Post
    Thanks for this.
    PM Sent.
    Dave.
    1996 TDI ES.
    2003 TD5 HSE
    1987 Isuzu County
    May 2009
    Tatura, Vic
    Quote Originally Posted by rick130 View Post
    Thanks Rick.
    I suppose that then confirms that it is ok for this mod.
    Dave.
    1996 TDI ES.
    2003 TD5 HSE
    1987 Isuzu County
    Oct 2018
    Margaret River WA
    Not sure you're correct on this Rick, I think it may apply to the later Deefers only. My D2a is one of the very last, May 04, and it had, until last week, the full EGR cooler circuit. It no longer has it as I've removed the EGR and cooler and capped off the coolant outlet from the oil cooler.
    Lawrence
    NSW far north coast
    Quote Originally Posted by Metoikos13 View Post
    Lawrence
    They have an EGR cooler but it doesn't draw flow from the oil cooler outlet.
    The oil cooler outlet is blanked.
    PYB500040 | FUEL COOLER OUTLET BLANKING PLUG - 2.5L TD5 DISCOVERY 2 + 2.4L DEFENDER 2007 ON | Land Rover | Defender 1983 To 2006 | Britcar (UK) Ltd
    Free Again Thanks Dan
    My Now wrecking D2A oil cooler coolant line for egr was factory blocked
    Apr 2012
    Whyalla, SA
    Did you read the price… now that’s out there!
