Results 1 to 9 of 9
Thread: EPB fault advice
    Oct 2019
    EPB fault advice
    Hi guys, my wife was driving the D4 and had to stop suddenly. Due to the laws of inertia, a Hungry Jacks lemonade decided to leap forward, spill and fill the EPB cavity. Nice one. Unfortunately now my EPB fault light is on and the red EPB light is flashing on and off and the EPB doesn't want to engage.
    Any advice on fixing this appreciated. I have a GAP tool if that is in anyway useful in this situation.
    Oct 2019
    The GAP tool picked up the park brake switch error. Cleared it. But the error message keeps recurring after being cleared. Thinking the EPB switch may be fried from the lemonade. Thoughts?
    BradC is offline Super Moderator
    No one of consequence
    Supporter
    Mar 2018
    Perth (near Malaga)
    Quote Originally Posted by BeeGee View Post
    Pull it out, give it a good bath in distilled or de-ionised water (a really, really good and maybe multiple baths), a good shake to disperse the water and into a fan forced oven at 60C for a couple of hours to thoroughly dry it out.
    It's likely that being powered on in in the presence of sugary water for a prolonged period has caused some nice electrolysis, but unless you are well versed with electronics further disassembly and "correction" might be out of your league. If not then a thorough disassembly, scrub with a toothbrush using the aforementioned fluids, a good oven dry and re-assembly might be a better bet.
    An even better mix might be a 70/30 mix of Isopropyl Alcohol/DI water, but you'd want a good DI water rinse before putting that one in the oven.
    Oct 2019
    Thanks Brad. Will see if I can get the switch out. I've read some have had to remove the console to get access, whilst one thread someone removed the switch by lifting up and sliding forwards (after screw removal). Will see how I go.
    EDIT: Got the switch out. Bathed in distilled water. Removed and vigorous shaking. Wiped off excess distilled water. In oven now on 60deg for 2hrs. Fingers crossed.
    Supporter
    Mar 2018
    Perth (near Malaga)
    I was doing this on one of the kids toy trains one day while the wife was out. She came home with a pie, didn't even look in the oven or stop to think "Huh, why is the oven on?" and just wound the thermostat up to 180. The train didn't come out well.
    Oct 2019
    Quote Originally Posted by BradC View Post
    Ha ha, yeah I did think of that. Unfortunately no luck with the above so back to square one. Probably need to buy a new switch.
    Is it safe to drive with no EPG and the warning lights on? I assume so. The EPG is just for parking and you can still put it in park yeah?
    Trying to pry this switch apart to clean with isopropyl alcohol. Is there a trick to pulling this thing apart? There is a small hole on the base as seen in the photo attached. Is there a screw hidden in there? I can't see a screw with my eyes, or feel a screw but doesn't want to come apart.
    Nov 2017
    West of Perth
    The trick to dismantling is to be very careful. There are no screws, just those fiddly little tabs.
    I'd already paid over the odds from the local stealer when I bought one and replaced mine myself, so I didn't care about damage and munted it in the process.
    Full story here:
    EPB Switch failure - U2001-01 (2 Switch general electrical failure
    The second trick is to buy a new switch online. Half the price of the dealership parts department.
    Also, check PowerfulUK videos on how to get the switch out. D3 is a piece of cake, D4 is easier with the console out.
    (See link above for another link to video)
    If at first you don't succeed, that's one data point. - xkcd
    2011 Discovery 4 SDV6 HSE
    Brisbane,some of the time.
    Just replace it,they are not that expensive.
    After replacing mine,i pulled the old one apart and it was full of dog hair.
    The worse thing is the EPB won’t work once it faults,not much fun with the van on.
    Mine played up over a period of 6 months,intermittently.
    Oct 2019
    Just to close this one out from a few weeks ago.
    I bought a new switch from a Perth dealership and installed it. All working perfectly.
    BTW, there is no need to remove the console. Removal of the old and installation of the new EPB switch is pretty easy if you lift the front of it as you slide it forward.
