Thread: Colour?
    Mornington Peninsula
    Colour?
    I have a 94 300 tdi Defender 110 Ute and trying to work out which colour white it might be. Could be chawton white or alpine white. Which one more likely?
    2022 Defender D250 S being set up for touring.
    '83 RRC 2 door 300tdi on club plates
    '82 RRC 2 door almost finished on club plates (will always be nearly finished!)
    2013 Freelander (wife's)
    1994 Defender ute hopefully on club plates one day
    May 2008
    Bundaberg Qld
    At a guess, I would think Alpine white as ( I believe) Chawton White is a Disco only colour.
    Apr 2012
    Whyalla, SA
    What’s the plate say?
    NSW far north coast
    Quote Originally Posted by pop058 View Post
    My old '98 130 was Chawton White. Colour?
    As Tombie suggested, check the compliance/build plate.
    Oct 2013
    Richmond, NSW
    My 1999 Td5 is Chawton White, my 1996 300Tdi is Alpine White.
    Cheers - Simon
    Travelrover
    Adventure before Dementia
    2012 Puma 90 - Black
    1999 Td5 110 Ute - White
    1996 Tdi 300 Wagon - White
    Ireland
    The best way to be sure is to go to a motor factors and get a small amount of each colour mixed up. I do that for touching up purposes. It will not be expensive and you can compare the samples to the body work. Put a brush stroke of each on the body somewhere and you will see which one matches the origional.
    Just had it confirmed it is LRC456 Alpine White. Thanks guys....
