I'm no expert, but I don't think you need it, pro some mesh will hold the bits together if it cracks, con it will make the concrete pour more difficult.
I have some outdoor lights on a post. They are not as high as I would like, so I am making some concrete spacers.
The actual light will be bolted to a flange on some 2 inch water pipe which will be concreted into the ground at correct height.
What I am making is a spacer out of concrete. There is nothing structural. It is just for ascetic purpose.
My question is, do I need to put reo in the concrete. I know concrete pavers don't have reo.
Below is a pic of the mould. It is about 330 mm deep and the concrete at the top will be about 50 mm thick.
Pic on the right is the lower section of the light post.
Dave.
I was asked " Is it ignorance or apathy?" I replied "I don't know and I don't care."
1983 RR gone (wish I kept it)
1996 TDI ES.
2003 TD5 HSE
1987 Isuzu County
2005 D3 TDV6 Present
1999 D2 TD5 Gone
Hi,
Are you casting the bolts into the plinth as you go?
Link them with a welded re-bar before casting.
I would also add a ring or two of reo in the mold as you fill it.
Dave.
1996 TDI ES.
2003 TD5 HSE
1987 Isuzu County
If you use dynabolts or similar that close to the edge of the plinth you are likely to break the edges away as you tighten the dynabolts. The tensile strength of concrete is somewhere around 10% of the compressive strength. I would make a template of plywood with the hole pattern drilled, then use that to hold some all-thread or long bolts whilst you weld them as a cage with some light crossbars, that will serve as reinforcing for the concrete and a secure anchor for the posts. A very simple little fabrication job that will pay off in being much easier than drilling all the holes in concrete and ensuring your plinths don't break up. We used to do the same on a much larger scale for shed footings up to 150' clear span.
From looking at your drawing and design
The post will be supported by the footing In ground
This is merely a spacer
Another option over making a seperate concrete spacer is to make your form slightly larger dimension than the pole
Bolt plate.
Do the footing with post/ plate set in place.
Now place your MDF formwork around the post and mix up a bag of durabed cementous grout - if you are using a form you can mix it to pourable consistency. Pour into the MDF form and let it set up
Grout will give a nicer surface finish - and a poured grout will seal better to the ground/ footing. I’ve painted Durabed and it takes paint better than raw
Concrete in my opinion
That’s the way I’d swing the cat ?
Linky
Lanko 20kg 701 Duragrout Structural Grouting - Bunnings Australia
Steve
Simply get taller posts to suit, Job done![]()
4.6m Quintrex boat
Back to your original question, don't put reo in it. Reo needs to be at least 50mm from the edge of the concrete to stop ingress of moisture causing it to rust and consequently blowing the stucture apart. Given the concrete will shrink as it cures, there will be no load on it, therefore just go for it. If you're not experienced with concrete mixing, be very careful adding the water. as you get near the correct consistency (plastic), a tiny quantity of water too much, can cause it to be too wet. Hasten slowly.
Don.
I can give some concrete advice.
Listen to your father
Be good to your mother
