A lot of variables would come into to play when checking fuel consumption but in any case, good result for you.
 Master
						Supporter
						Master
						SupporterHad the ECU done earlier this year. Mainly to get rid of lag and any issues with EGR's. Have noticed a very smooth power application. No noticeable power increase but I never stick the boot in. However, have noticed a big difference in fuel usage. Just vehicle around town getting about 8.5-8.6 l/100k. Last two day was first time I've been able to take the caravan anywhere. It's a large van, 24ft and 3500 ATM. Towing weight at the moment probably about 3250-3300. Trip from 25km out of Bathurst, into Bathurst and up to Coonamble. Cruising speed about 90-93km/h. In the past fuel consumption towing van would be about 15.5-16.5. Now, 13.9 l/100km. Towing easily. Local Indie sent the ECU to some mob in Adelaide.
2014 SDV6 SE, Fuji White, ARB bar, Fyrlyt 5000, Pioneer Platform, Traxide D4-5S, Maxxis 980 Bravo, GOE Compressor Plate, ICom-450 UHF, Red Arc Tow Pro.
Elite Murray 2 Caravan 24'4" Tare-2917kg, ATM-3500kg
 Master
						Subscriber
						Master
						SubscriberA lot of variables would come into to play when checking fuel consumption but in any case, good result for you.
Rod
D4 MY16 5 seat TDV6 - LLAMS, Custom Drawers, OL Bar, Toyo Open Country, GOE Rims, Lithium DBS, eDiff, OA Long Range Tank, GAP Tool, Tracklander rack, Mitch Hitch, TPMS & Safari Snorkel
 Master
						Supporter
						Master
						SupporterTrue. I’ve travelled this route about a dozen times with the van visiting daughter and family. I’ve never had consumption as good as this. Whilst I realise lots of variables on any given day getting below 14 l/100km when cruising at over 90 is better than I’ve ever got in 5 years of towing this van. Will see how I go with return trip tomorrow.
 ChatterBox
						Supporter
						ChatterBox
						SupporterHave you actually calculated the result yourself?
If not, it's worth doing - as a lot of tunes are done in such a way that they will show better economy but actually be worse.
If it IS actually better... Good for you!
James
Is that the TRS tune that you’re talking about?
"Land Rover - making mechanics out of everyday motorists for nearly 70 years"
 Master
						Supporter
						Master
						SupporterYikes, I hope not. I tend to just rely on the computer calculation. Bursting my bubble that the ECU re-map might be giving me fake news, lol. Will fill up in morning for trip back home and do the manual thing. Fingers crossed. With covid I've not been able to do any long trips to check long term towing.
 Master
						Supporter
						Master
						Supporter ChatterBox
						Supporter
						ChatterBox
						Supporter
						ChatterBox
						SupporterThey would be a reseller
