Results 1 to 10 of 14
Thread: Key Remote
    Feb 2013
    Queensland
    Key Remote
    Hi all does anyone know of any one that fixes the key remote on the disco 2 and how I get in touch with them.
    thanks Phil
    Back down the hill.
    Where abouts in Queensland are you?
    Feb 2013
    Queensland
    Thanks V8Ian I am in Toowoomba but I don't mind posting my circuit boards away for repair as I have a spare would like my original ones going again.
    Back down the hill.
    Is it definitely the circuit boards? Or just the micro-switches?
    Feb 2013
    Queensland
    I'm pretty sure it's the micro switches but I am crap with this kind of thing if I tried to replace the buttons on theses remotes I would most likely destroy them hence I would like to find someone who can do the job .
    Mar 2015
    Horsham Victoria
    If you buy your own micro switches just watch the hieght of the switch, I had one fail so I ebayed a micro switch, it was slightly taller than original and I couldn’t close case as the button was depressed all the time, got the deemed onto inside casing and all is swell again.
    Mar 2015
    Horsham Victoria
    There was a fella in uk I reckon that was fixing them, via post from memory maybe eBay uk just can’t remember exactly.
    Back down the hill.
    PM sent.
    Two Rocks WA
    Hi I can fix them and have the correct switches..but I am in Perth..
    up to you if you want to send to me.
    I did a D3 key fob today..not switches but battery that is soldered into the board..but this one had been in the washing machine a year ago, so had some corrosion, however I got it working🙂
    Range Rovers Have Charactors inside them
    LROCWA Ex member 23 years
    1971 Series 2A
    2004 Discovery2a V8 Auto
    2003 Discovery2a TD5 Manual
    1982 4door man (sadly now gone)
    1989 Vogue auto
    2011 TDV8 Vogue
    What would life be without a Rangie?
    Feb 2013
    Queensland
    Sorry V8Ian but I have no pm in my inbox can you please resend it may just be my computing skills.
