is that the stainless steel type?
if so, some have used and they break very quickly at the collector.
.... avoid!
So the e-bay junker deal for the ASI TD5 replacement manifold, any one used it and any feedback ?
.... avoid!
Arthur.
'03 D2 Td5 Auto
'03 D2a Td5 Auto
CRAP,CRAP,CRAP,CRAP,CRAP,CRAP,CRAP,CRAP
Stay away, only use allisport manifold or stock manifold
03 D2a Manual Td5 Modified, Ashcroft lockers F&R, Ashcroft R380,Atb lt230, Ashcroft Rear axles, AS manual IC, AS exhuast manifold, AS Coolant bottle, 3inch exhaust, alive GTB550 VGT, billies 7100s, 3inch lift, 4inch staino snorkel, 35s beadlocked
The only fabricated manifold that might hold up to use is the Dark Side Developments version, and I don't know if that'll fit a Disco?
It has a beautifully machined merge collector, so should perform really well.
sexy bit of kit , but needs to be used with the garret gtb/ gtd range of VGT, I see they sell a kit with a gtb 2260, which no doubt would be fine for fast road but personally think a better compromise for good torque lower in the range as well would be the 2056 with the right tune.
4LOKO is running the turbo technics VGT which wouldn't fit the darkside manifold without mods.
stock, modded and ceramic coated or allisport as mentioned is the go.
Roger that, thanks all. That answers that :P
2 weeks![]()
