Results 1 to 10 of 17
Thread: Rattle Genuine Tow Hitch Receiver Fix???
    Jan 2016
    Tolga FNQ
    Hi everyone.
    Our new MY 2022 D350 with the factory tow hitch receiver and hitch is seriously clunky when towing our 8x5 tandom trailer, let alone what it will be like towing the 20.6 ZoneRV Off road caravan when it arrives.
    The hitch receiver isn’t equiped with a bolt to tighten the hitch up to prevent rattle, as per say a Hayman Reece unit or other tow hitch so has anyone else with a factory late model hitch experienced the same noisy towing and if so, have you been able to retrofit a fix such as a jam bolt for the tow hitch or some other work around?
    Im seriously surprised that Range Rover would sign off on a tow bar with this much play in it (seeing as horse floats are a target market) and may even refer it back to the dealer for review as in all my towing, it’s the worse I’ve ever experienced, and that includes my Defender with its current Pintle hook military trailer and Dixon Bate NATO hitch!
    Thanks for any info and best wishes.
    Ken
    Dec 2011
    Bundeena
    Quote Originally Posted by Baytown View Post
    Hi everyone.
    Ken
    Something like this should sort it out (I assume it is a standard hitch set up):
    Sean
    Jan 2016
    Tolga FNQ
    Good on you Sean
    Thanks Sean!
    I had one of these a few years ago but lost the parts to it , used it on the Defender.
    ‘I’m off to EBay to order another for the Rangie.
    Good on you Sean mate.👍
    ‘I’ll report back with how it improves the towing experience.
    May 2003
    On The Road
    Towbars.
    English square tubing used to make the rear tow point is 52mm ID
    The Australian supplied tongue is the standard Hayman Reese 50mm OD
    To the Owners that tow stuff,, does the hitch bang around much?
    it flops around like a ***** in a post hole
    with this much slop wont the ball weight pivot on the pin?
    can anyone measure a standard GEN hayman Reese receiver please?
    May 2003
    On The Road
    Are there pics anywhere of how the hitch is mounted to the car?
    May 2003
    On The Road
    Just talked to a Customer Service Rep for Hayman Reese (Cequent ?)
    and the receiver has "a tolerance of 1-2mm"
    I'm sure the steel supplier is good with that......
    omg....
    Dec 2011
    Bundeena
    Check out this thread Pete, it might have what you need:
    Sean
    May 2003
    On The Road
    anti rattle thingo on!
    will report this evening,,,,
    Milenco mirrors on!
    Aug 2021
    McCrae Vic
    Looks like a great product, however isn’t the Land Rover, Range Rover ball assembly supposed to a solid 2” section of steel as opposed to the hollow one?
    Jan 2016
    Tolga FNQ
    Solid vs hollow channel
    Dad, I’m pretty sure the OEM box section hitch arm is hollow, but I’ll check this afternoon.
    I’ve removed it from the vehicle so haven’t fitted the anti rattle pin assembly from Hayman Reece yet, but again, I’m sure it’s standard hollow box section.
