Results 1 to 10 of 18
Thread: Discovery 2a V8 SE advice
    Jul 2021
    Sunshine Coast
    Hi All,
    I'm new to this forum and this will be my first post outside of my introduction post. I am looking for a Discovery or RR from D2a to D4. I missed out on a D2a HSE v8 I think was owned by a forum member but another one has come up for sale.
    It is a 2003 SE V8 with 128k km. My reading and research has indicated to me it is only a matter of time, if it hasn't already, before the liners will slip in the rover V8 requiring a Top Hat liner short block as a permanent fix.
    For those of you who have done the Top Hat engine would you do it again?
    What sort of money were you up for? Triumph Rover Spares has a bare block listed for $2950
    Would you consider a LS engine swap as an alternative? Has someone here done an LS swap? Have seen LS engine, tranny and all associated parts required for a conversion without adaptor plates and mounts listed around the $6000. I think you can buy almost everything else off the shelf from LRA and Marks 4x4.
    Failing this I'd probably try and find a 2.7l D4 or TDV8 RR. What you all think?
    Avoca Beach
    You are probably correct as it is the operating temperature that causes the problem.
    if you replaced it with a top hatted block, AND ran it at 88C the new engine would probably last "forever"
    My 91 RRC was going strong at 225KK as it had NEVER been overheated over 100C . Camshafts were another matter of course as the base diameter of the cam lobes is too small for them to last a long time.
    Regards PhilipA
    Back down the hill.
    Fit a low coolant alarm. The liners only slip if the motor has been overheated.
    Jul 2021
    Sunshine Coast
    Are you telling me it can be avoided?
    Back down the hill.
    Liner slippage is the result of overheating. Keep the temperature within range and the liners wont move.
    May 2003
    On The Road
    PM me!!!
    Sep 2012
    Adelaide Hills
    i overheated mine many times (HG problem)
    20,000km later and liners had not moved.
    Current Cars:
    2013 E3 Maloo, 350kw
    2008 RRS, TDV8
    1995 VS Clubsport
    Previous Cars:
    2008 ML63, V8
    2002 VY SS Ute, 300kw
    2002 Disco 2, LS1 conversion
    Jul 2021
    Sunshine Coast
    PM me!!!
    PM sent
    May 2008
    Bundaberg Qld
    PM me!!!
    Quote Originally Posted by sippahodge View Post
    PM sent
    Pedro, ignore my PM ( apparently)
    Jul 2021
    Sunshine Coast
    D2a Vs D4
    Do you think a 2.7l D4 is a better all round option for getting out with the family onto some islands and 4x4 camping? More reliable than a D2a? would use less fuel and probably a lot more comfortable?
