Results 1 to 10 of 14
Thread: Front Bumper Damage
    Jan 2018
    Boonah Qld
    Front Bumper Damage
    Teaching my 10 year old Grandson to drive and he clipped a post and damaged the front bumper plastic. Yes I was sitting beside him and even had my hand on the hand brake but .... well that what can happen. I decided to fix it with fibre glass. Taking the baumper off is not covered at all in the D1 manual. Rave gives a version that isn't the same as my car perhaps to meet ADR's. There are two extra bolts luckily slotted and two extra stays each with two small nuts to remove. That of course takes the whole thing off including the steel backing. To seperate that requires drastic action. Some is glue that actually sticks and some is a mastic type product that peels away. Behind the number plate is well glued and so I used an angle grinder. I will glue it back but it is covered by the number plate. Check out some photos.
    The extra bracket and nuts on each side.
    Jan 2018
    Boonah Qld
    Photo showing damage done trying to seperate the plastic from the metal.IMG_577.jpgIMG_578.jpgIMG_579.jpgIMG_580.jpg
    Jan 2018
    Boonah Qld
    Photos showing making strenghthening aluminium strip to hold all the pieces in place. Once it is all in place I'll fill the back with fibre glass. The front will have some bog added to cover all the cracks. Hopefully!
    Sep 2020
    Portland, OR USA
    God we're so uptight here in America people would lose their marbles online over a 10 year old driving. 10 years old -- go grandpa go -- hell yes!
    May 2015
    Williamstown, Victoria
    Quote Originally Posted by Nashvegas View Post
    Yeah, I know. Why so old!!
    Build date 11th Oct 2003
    LROCV #1410
    Jan 2011
    Gippsland
    Front Bumper Damage
    Quote Originally Posted by Robflocar View Post
    Can you fix it Pa?
    Yes! I certainly can - and it’ll be as good as new in no time Front Bumper Damage and nobody will ever realise it was brokenFront Bumper Damage
    You’ll be immortal after this Front Bumper Damage
    Memories are priceless aren’t they …..
    LROCV member #131
    1999 build D2 TD5 Auto, Mantec snorkel, 2" LRA spring lift, ARB on board air, Ashcroft ATB, CMM air ram CDL shifter, swag & gold pans ....
    Normanhurst, NSW
    If the cracks in the front aren't too big you may fine a product known as 'Q-Bond" will be better than "bog". Very easy to use - form a 'v' in the crack, drop the powder in and apply a few drops of the glue. Only takes a few seconds to react and harden before you can sand or file any excess off.
    I used it to repair my D2 bumpers and after sanding & painting they looked like new.
    Available here Q-Bond Ultra Strong Adhesive with Reinforcing Powder Small Repair Kit 6001651023565 | eBay
    Roger
    Jan 2018
    Boonah Qld
    Udate photo.IMG_604.jpg Showing the bits that are missing filled with tape to hold the fibre glass and epoxy.
    Jan 2018
    Boonah Qld
    More update photos showing the fibre glass epoxy in place.
    The last photo shows that the left also shattered when I tried to replace the bumper on the car.
    Jan 2018
    Boonah Qld
    I should also say I had a generous offer of a bull bar/bumper but have decided to keep the car as original as possible without spending much money. After all it is only a tow car for my tandem car trailer and occasional caravan use. No off road at all, did that for 26 years in the Army, fun at the time but been there done that.
