Results 1 to 10 of 17
Thread: Rough Idle/misfire on start up
    Jan 2013
    Mt Barker SA
    Hello folks seeking advice
    My disco just in last 2 days has on start up, idled rough/ misfire for about 30 seconds then runs sweet. It has been really really cold and wet so not sure if just a slow glo plug? I am going to replace the injector harness and run an injector cleaner through.
    Have checked oil for signs of diesel but all clear so don't think it's a failed copper washer?
    I don't remember it ever in the 8.5 years I've owned it, have this on start up before, but I also don't remember ever having such cold and wet weather Rough Idle/misfire on start up
    The old girl gets hand controls fitted next month so need to ensure she's all ok. Also isn't getting run or driven much at the moment and had not been started for a couple of weeks before starting up 2 days ago and first having this rough start up. Then started up yesterday and the rough idle was even shorter (like 15 seconds) than the day before.
    Thankyou in advance folks.
    I've not checked the red plug for oil in some time but every time need to clean that I've have a consistent misfire and power loss.
    Avoca Beach
    The diesel in oil is generally caused by the Oring at the top of the injector failing.
    Generally if the copper washer at the bottom fails it causes compression to force air into the fuel rail in the head and cause no start or rough running.
    So probably your injector washers are crook.
    I have never seen my glow plug light on and doubt whether they activate anywhere in Oz , although it can get damn cold in SA.
    Regards PhilipA
    Back down the hill.
    Do you get the misfiring when starting it while warm?
    Could be fuel running back.
    Jan 2013
    Mt Barker SA
    Ill see what happens when start it warm
    Theres no diesel in the oil though at least
    Jan 2013
    Mt Barker SA
    I've ordered glow plugs. Haha why does it have 4 for 5 cylinders?
    But it's fine to start after that initial cold start, even if car isn't warm yet
    Back down the hill.
    I doubt it's glow plugs. Could be as I previously suggested. What check valves are in the fuel system?
    Can the FPR allow air into the system?
    Leonie, have you had any small leak from the right side, back of the engine?
    May 2015
    Williamstown, Victoria
    Regards PhilipA
    Yes, -5C once in the snow, I did not see the glow plug light. Maybe I missed it.
    Build date 11th Oct 2003
    LROCV #1410
    Jan 2013
    Mt Barker SA
    No fuel leaks had that leak in the other disco here before. Mine isn't though.
    The old girl runs sweet after that first cold start. I have had a few weird starts before this rough 30 seconds or so that isn't battery or starter or anything. Can't explain it haha.
    My glow plug light always comes on! It's been taking longer to go off recently. The glow plugs were not expensive though so is an easy thing which I'll feel happy its got fresh ones even if isn't the cause Rough Idle/misfire on start up
    Jan 2011
    Gippsland
    Regards PhilipA
    Check that the relay is still there and/or still working - my glow plug lamp illuminates for all starts where the coolant temperature is below 20degC. The glow plugs are vital in the engine starting strategy with the ECM controllIng pre heat and post heat time. I have a replacement set of NGKs to go in after I modify the disintegrating push-on connectors….
    LROCV member #131
    1999 build D2 TD5 Auto, Mantec snorkel, 2" LRA spring lift, ARB on board air, Ashcroft ATB, CMM air ram CDL shifter, swag & gold pans ....
    Avoca Beach
    I replaced mine about a year ago as I got strange resistance readings. I was able to repair the loom with large shrink wrap .
    However I have never had any error codes and the car always starts on all 5 first cylinder usually, and never with white smoke. I have a Nanocom but the references on landyzone were for Lynx. I don't know whether Nanocom reads the 2 error codes that SierraFerry noted or not.
    I will however check the fusible link and relay. Thanks for the heads up. My car has certainly been under 20C at times.
    Regards PhilipA
    The fault codes are
    3070: Glowplug Lamp Drive Open load logged, and
    3071: Glowplug Relay Drive Open load logged.
