Results 1 to 4 of 4
Thread: L322 light bar install.
    Wandiligong Victoria
    I don't like these light bars or the bracket but it was a quick and simple solution. Without a bullbar this is the easiest and cheapest solution I could see and I already had the light bar sitting in the shed.
    Mar 2007
    Looks good Gilly !
    It's the reversing lights on mine that need replacement. Any ideas ?
    Looking at these
    Trailer Tow Hitch Mount Bracket + 4'' LED Spot Flood Offroad Work Reverse Lights | eBay
    I have put LED bulbs in; better but really good enough !
    Laurie
    2010 TdV8 Autobiography, D2 Td5, RRC 4 Door VM/300Tdi, RRC 2 Door V8
    Apr 2012
    Whyalla, SA
    Looks good...
    If you whip the bracket off and have it powder coated black it would look even better
    I reckon you would be right Tombie. Without the Grill and more black it even looked better.
    I'm not sure about reverse lights Laurie. The option you are looking at would provide the light and would be easy but not sure if its ideal. I'll have to have a look at the car as you can never have enough light, especially around here with Deer, Kangaroos and wombats.
    There are some very good small led lights available. I fitted some to the defender and they are really good but there are more mounting options on a 130.
