Thread: Check worn ball joints
    Jan 2014
    Tweed Heads
    Hi all I have a thump in left front when i go over a bump not a loud thump but still a thump i have replaced lower suspension arms l & r about 60k ago so how can i check uper ball joints l have a 2002 l322 td6 any help will be great
    Many thanks denis
    Jan 2014
    Tweed Heads
    Follow up worn ball joints
    Hi again i am still hoping someone can tell me the best way to check worn ball joints
    Thanks denis
    Aug 2010
    Sunbury, VIC
    Ball joints are easy to check. Have someone rock the steering back and forward (engine off) just enough to pick up some pressure - while you look or feel if there is any movement between the steering arm and the track rod at each side.
    Clunk could also be the strut mount rubbers up top - they could be quite perished by now on a vehicle of that age, could also be the strut itself it it’s never been replaced - the rebound on old struts can make a noise when they are shagged.
    Jan 2014
    Tweed Heads
    Thanks homestar will check ball joints today , new Delphi strut fitted left side 45k ago will keep you posted
    Many thanks
    Jan 2014
    Tweed Heads
    Hi homestar l have been checking the ball joints both sides upper and lower and can not see any movement so i will keep looking
    Many thanks any new advise would be great
    Denis
    Mar 2007
    Denis
    If the top and bottom ball joints, and the tie rod end check out ok have a look at the the drop links !
    Laurie
    2010 TdV8 Autobiography, D2 Td5, RRC 4 Door VM/300Tdi, RRC 2 Door V8
    Jan 2014
    Tweed Heads
    Hi Laurie thanks for the advise l replaced the sway bar 4 years ago but did not replace the drop links you could be spot on will check them out , should i replace both sides
    Regards denis
    Mar 2007
    Denis
    I'm old school on these things, if one side has worn out as far as I'm concerned the other side can't be far behind.
    Laurie
    Jan 2014
    Tweed Heads
    Hi Laurie thanks for the feedback i am chasing price today
    Again many thanks
    Denis
    Jan 2014
    Tweed Heads
    Hi Laurie thanks for the advise l replaced the drop links today and as always you have been spot on many thanks again
    Regards denis
