Certainly if the battery is down a bit or you have just started I see 14.5v then after the engine has been running for a while and the battery gets a bit of charge to recover the starting loss it settles back to 13.5v and sits there.
 Master
						Master
						I measured the battery voltage as part of the process of identifying wiring to connect my additional camera. Was surprised when my multimeter read 14.84V. To confirm I then measured the voltage across the battery terminals and it was the same.
Admittedly the meter is a brand new cheapy to replace my Fluke so there could be a calibration error however this voltage is rather high.
Appreciate any comment as this appears abnormal.
 Master
						Master
						what's abnormal? 14 volts is normal from the alternator to charge the battery. It'll fluctuate in these cars because of the smarts.
Hi Gravy, 14.7v is normal when first starting your motor.
The slightly higher voltage you saw was probably because of cold ambient temperatures.
Here in Australia, that is about as high as it gets unless in very cold areas.
In Northern Europe, 15.5v is normal in winter months, so yours is fine.
 Master
						Master
						 Master
						Subscriber
						Master
						SubscriberBefore: Ser 2a LWB, Ser 3 S/W, 1979 RR 2 door, 1981 LR Stage 1 V8 (new), 1985 LR 110 V8 County (new), 2009 RRS TDV8
Now: MY13 D4 TDV6. "E" rear diff. Cambo's magic Engine & Auto Tune. 1968 Austin 1800 Mk1 auto (my 5th)
