Results 1 to 10 of 18
Thread: Smoky TD5 esp idling
    NSW SW Slopes
    Helping a local D2 TD5 owner diagnose engine problems whereby it runs well for a couple of weeks then looses power then eventually won't start. Also in recent months it started producing lots of whiteish smoke especially while idling, except none for the first couple of minutes after a drive. Oil in the ecu connector was cleaned with metho then dried, hoping that to be the cause of the low power and non-starting. The I/C inlet hose has no signs of delamination and the smoke is whiteish, not black. A new injector loom will be obtained and possibly the external loom too.
    The crankcase breather doesn't appear to be anything other than straight through. I don't recall what they look like inside but there was no sign of a spring and plate that I expected to be visible in order to close at higher engine revs. Can someone advise what should be visible in the valve please? I'm wondering that if the valve is non-existent then the I/C may have an excessive volume of engine oil although I would then expect smoke under power rather than when idling. There doesn't seem to be excessive blow-by from the breather when idling although a little smokier than I expected. The exhaust smoke at idle doesn't decrease if the breather pipe is detached.
    Any suggestions?
    Thanks,
    Graeme
    Edit: 218K kms, auto, MY2004 owned since 2008.
    Nov 2014
    Nirvana near Albany W.A.
    If the white smoke smells like diesel rather than oil I'd be suspecting injector washers, does the pump sound normal with ignition on engine off ?.
    Mar 2016
    Adelaide
    Could it be a blocked turbo drain hose? Thought oil filling into the turbo world give you occasional white smoke.
    "Land Rover - making mechanics out of everyday motorists for nearly 70 years"
    NSW SW Slopes
    The smoke smells like kerosene not oil so presumably diesel and smelt the same when no smoke after a run. The pump sounds normal although I don't recall hearing mine's pump so loudly but I wasn't accustomed to standing outside my vehicle when starting it. The owner said that a lot of the time he has to wait for the pump to go quiet before the engine will start. This was in response to my saying no need to wait after switching on the ignition....
    I never had fuelling issues with my 2 TD5s. Thanks for replying and for the suggestion.
    NSW SW Slopes
    Quote Originally Posted by John_D4 View Post
    The smoke is constant at idle once it starts after a run and it's not blue or smelling oily. Unseen I suggested unburnt fuel but wasn't 100% sure when at the vehicle.
    The owner had sent the vehicle to a local European vehicle "specialist" who had no idea so sent it to a fuel injection specialist who diagnosed it as needing a full rebuild but with no explanation for the power loss or non-starting. The oil in the ecu plug was significant even though the owner had removed the sealing ring several weeks ago at my suggestion but the connector hadn't been dismantled and cleaned properly.
    Thanks for the suggestion.
    Apr 2016
    Country Vic.
    yeah, sounds a lot like injector seals. Smokey, power los and hard starts .. same happened to my brothers(now my) D2 some time back.
    Also, inspect the FPR too. If possible, check fuel pressure.
    When the injector seals issue started and engine would lose power, it got to the point where it lost all power and shut down. It was a gradual change from losing power to shut down.
    While it was still in the losing power stage, when we felt it losing power, we'd pull over somewhere, shut it down, start it up again and it felt fine.
    When it got to the shut down phase, it happened randomly and you could be stuck in the middle of the road. It'd be a mongrel to start again. Doing the fuel priming routine got it started much quicker than simply trying to start it again. Even if the priming routine was interrupted say after 60 sec .. not the full procedure.
    Arthur.
    '03 D2 Td5 Auto
    '03 D2a Td5 Auto
    NSW SW Slopes
    Thanks Arthur, your conditions match exactly with what I was told happens with this one. Therefore perhaps the oil at the ecu connector may have had nothing to do with the current misbehaviour.
    The injector specialist noted that the fuel pressure was a bit low but the owner only got a shrug when asked by what standard. From the reports they didn't know anything about the TD5 and therefore may not have known the normal pressure.
    Jul 2021
    Hatton Vale qld
    Smoky
    Any suggestions?
    Thanks,
    Graeme
    if the injector seals are failing fuel pump will get a loud sound like it is sucking air, the engine compression pushes fuel out of the lines then car starts slowing without accelerator response and then stops. Turn off wait and then turn ignition on, don't start car but pump accelerator 5 plus times and car will purge fuel lines. Get the seals replaced asap
    NSW SW Slopes
    Thanks - the owner is awaiting the arrival of an injector overhaul kit.
    Jan 2014
    Perth Western Australia
    *My guess is the in tank low pressure fuel pump.
    *only a VDO replacement pump, the cheap ones last mere months.
    *expensive item but 15 mins to change out.
    *Doing the injector harness, cleaning the external harness and clean the red plug on the ecu are all good maintenance items anyway.
    *As is a fuel pressure regulator.
    Daz
