Results 1 to 10 of 12
Thread: Starlink on the go?
    Sep 2010
    The Hills.
    152.79 MB
    Starlink on the go?
    I was under the impression that Starlink was tied to a particular sat that was controlled by your address. This video seems to say that all you need to do is enter a new address as you move around. If true it would be brilliant.
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    The satellites are moving rapidly relative to your position on earth, so you are not tied to a single satellite.
    But you are tied to a location (so the satellites know where to expect you). And yes, this location can be changed - the system just has to know about it. It is up to Starlink under what circumstances they allow this, and you can expect there to be issues in some locations with too many customers or with licence restrictions.
    They are working on an antenna for moving vehicles, but size and cost (and possibly power use) are likely to limit this for private users, and the physics suggests that it is unlikely to happen for vehicles as small as a car.
    Jul 2011
    Yarrawonga, Vic
    I stripped the antenna from my starlink dish and surface mounted it on the roof of my truck. My truck body is 50mm coolroom panel so it was easy to dig out enough foam to accomodate the phase array antenna, once you disconnect the motors the elon magic still steers the beam toward satellite. I really dont know why they bother with the motors, maybe now there is enough satellites to not be a problem.
    Once you move a few times the software switches to roaming so you do not have to change addresses.
    temporary duct taped to weather seal and a piece of core-flute duct taped over the top for extra protection. The antenna is also bolted from the underside.
    The speeds are the same as when it was mounted per factory on roof of house.
    277758374_4962045520543865_3819342530344690208_n.jpg 278002769_4962037153878035_628656867863198687_n.jpg
    277998574_4962040947210989_4579253236974484459_n.jpg 277999314_4962044693877281_2151115126998412584_n.jpg
    Kallangur, Brisbane
    If I may ask, what is Starlink costing?
    I work remotely sometimes & phone coverage is very ordinary at times (like now 1meg down & 25 up) so better comms would be nice.
    + 2016 D4 TDV6
    Jul 2011
    Yarrawonga, Vic
    Quote Originally Posted by Milton477 View Post
    The kit was around $700 from memory.
    $139 a month. cancel anytime you like, they will also refund the kit if you want to pull out, ( well probably not mine)
    May 2003
    On The Road
    What sort of data does 139 a month get you?
    The market for good mobile satellite coverage in OZ would be HUGE....
    Jul 2011
    Yarrawonga, Vic
    unlimited data, its the only option AFIK.
    Yes, although for how long?
    Equipment costs have gone up now, and you can expect more rises. The dish is being sold for a lot less than manufacturing cost, so it is hard to tell what it may go up to. Could go down, but I would not count on it.
    Jul 2011
    Yarrawonga, Vic
    As the constellation becomes fully deployed future generation antennas should be cheaper is they don't / won't need the complication of the setup motors. Technically they are not a dish but a phased array antenna.
    Interesting news which may affect pricing. Amazon has just bought almost every available commercial launch spot on large rockets for the next ten years or so from all western rocket companies, (United Launch Alliance, Arianespace and Blue Origin) except SpaceX, to launch satellites for their new "Kuiper" system, which will compete with Starlink. But first launches are probably five years away, and two of the rockets (Ariane6 and ULA) are yet to even see a successful flight.
    In addition there is the European competitor OneWeb, which has previously launched about two thirds of it 648 satellites on Soyuz rockets, has now engaged SpaceX to do the remaining launches.
    So within a few years, there should be three competing LEO satellite systems operational - which should keep prices down.
