Results 1 to 9 of 9
Thread: Possibly manifold
    Jan 2011
    Burpengary, QLD
    Possibly manifold
    Hello learned people,
    Over got an issue with my td5, it makes a noise at about 2250rpm, very precisely, sounds like something thin is rattling, it's a metallic nose, I've re riveted the heat shield and been down the exhaust checking for movement beyond the expected, no joy.
    I was under the impression that a warped manifold would make a whistle noise, could the rattle be that, would the exhaust be leaking enough I can go looking for soot?
    Only had the car about 4 months, loving it, but I've had enough land rovers to know I should go looking for the problem before it comes looking for me.
    Any suggestions on what to check would be gratefully received
    P38 Range Rover , the best car in the world, when it's working
    Melbourne, AU
    Loose handbrake shoes.
    Pull the handbrake on a notch while it’s rattling and if it stops will confirm.
    _________________________
    1996 D1 V8 - gone
    2002 D2 Td5 ES- gone but still running elsewhere
    2013 D4 SDV6 HSE - gone
    2023 Defender 110SE D300
    Dec 2020
    Quote Originally Posted by finallyrangie View Post
    From what I have read around the place what your describing sounds more like the harmonic balancer
    Avoca Beach
    No, brake shoes.
    You will have to buy new ones and weld the backing plate where they indent.
    I posted photos several years ago but I must have deleted them.
    Regards PhilipA
    To test pull the handbrake on lightly when you are at 2250RPM . I bet the chorus will stop singing.
    Jun 2013
    Augusta WA
    No, brake shoes.
    Regards PhilipA
    Look up Land Rover Discovery II Technical Bulletin No: 0022 for the fix. Nick
    MY09 D3 TDV6 Zermatt Silver
    MY02 TD5 Bonatti Grey (Sold)
    MY00 TD5 520K (Sold)
    Jan 2011
    Burpengary, QLD
    Thanks for all the replies, I will be trying the handbrake this evening after work, if that's what the problem is I will try adjusting in Friday and look at getting some new shoes at the weekend if that helps, the handbrake is currently where the previous owner set it, about twenty clicks of upward travel but does hold very well.
    Jun 2013
    Augusta WA
    Adjustment should help but here is the tech bulletinIMG_20210811_0001.pdf.IMG_20210811_0001.pdfIMG_20210811_0001.pdfIMG_20210811_0001.pdfIMG_20210811_0001.pdf
    Avoca Beach
    Only problem with the above PDF is that it is almost impossible to fit the "red " strong springs, seeing there is a bloody great damper behind the backing plate. I have a set somewhere and I gave up and fitted the old ones, and they have lasted 7 years without noise return. I doubt you could get them anywhere now anyway. I tried for hours but couldn't get the 1/2 turn cup to engage as I couldn't hold the pin enough get the cup to the turning point..
    I just replaced the linings again because of the normal leaking rear seal, which I now have to replace again because the flange had a wear mark and its leaking again. AGGGGGH.
    If you don't want to buy a new backing plate you can fill the grooves with weld and grind it back, which is what I did. You can leave it a bit higher than stock and that achieves tightening of the springs.
    Regards PhilipA
    Jan 2011
    Burpengary, QLD
    Well I had a play with the hand brake on the way home, supported the rattle with a bit of pre tension, so I've tried to adjust the travel back to where it should be and I will start looking for the parts to do the repairs.
    Thank you all for your wisdom, as always the aulro community prove to be a fantastic bunch of people
