Thread: what diff oil 03-TD6
    May 2006
    Ulverstone,TAS
    After changing my T/C the other day. Thought I,d get some diff oil to change them as well.
    I,ve got some Castrol 75W-90 syntans for the front, but no one stocks Castrol fluids down here in Tassie.(specifically castrol saf-carbon mod plus 75w-90)
    Is the Penrite Pro gear 75W-90 Full Synthetic suitable for the rear diff?
    According to their website it is,but I thought I,d ask on here from the people that service these vehicles to make sure.
    TIA
    DG
    2014 Freelander SE TD4
    2003 Range Rover TD6
    92 disco tdi manual sold
    95 disco tdi auto gone
    Aug 2020
    Unless you have a locking rear diff (didn't come out till 2005/2006 I think) then it's syntrans for front diff and rear diff.
    I think rear was 1.2L and front is 0.8L
    Mar 2007
    Just be careful when you refill the diff oil ! The L322 unlike all other LR Variants and most other cars; the Diff filler plug is not the oil level indicator If oil runs out the diff is overfilled. Just measure the oil precisely. To me there doesn't look like much difference, but that's what it says in the manual. I only came across this info while researching about diff/e-diff on Ffrr.
    Laurie
    2010 TdV8 Autobiography, D2 Td5, RRC 4 Door VM/300Tdi, RRC 2 Door V8
    Aug 2020
    Nice you mentioned that Laurie! I put 1.2L in and it still wasn't running out...but I just shrugged and figured it had enough....turns out that was wise!
    May 2006
    Ulverstone,TAS
    Does anyone know where I can buy castrol products in Tassie.
    None of the auto places here stock castrol anymore.
    Has anyone used the Penrite 75w-90 in there diffs on early L322,s?
    May 2006
    Ulverstone,TAS
    Its alright, I found a box that I thought had power steering fluid in it but its syntrans 75w-90.
    Got 6 bottles of it so should be Ok for a few changes.
    Got lost with a lot of other stuff that I hadnt unpacked since I moved to Tassie couple years ago.
    Mar 2011
    Balbarrup WA
    RE penrite fluids and oils
    Quote Originally Posted by disco gazza View Post
    I use Penrite oils for diffs and motor and ZF fluid for tranfer case and auto, no issues in over 500,000 K's
