Results 1 to 8 of 8
Thread: Low Speed Squeal- Brakes
    Jul 2012
    Perth- South of the River
    Hi All,
    I've got a low speed squeal coming from the brakes. Happens mostly when leaving a car park. Will squeal all the way until I reach the road. It then stops and no sound until the next leave the car park situation.
    I've previously pulled pads out, cleaned the clips, greased and replaced. Didn't seem to help.
    I've done a search and can see some references to this but couldn't see any thing about the cause or a fix.
    Any help appreciated.
    Gone 05 D3 ARB Front Kaymar Rear Winch E-Diff LRA Tank Dual Battery
    Current 2015 SDV6 SE. Tow Pro Mitch Hitch Llams C/motives 70ltr w/tank 2 x comp Traxide BMS-2 x Aux 150w Solar Uniden Engel ARB drawer F/Runner rack Light bar
    Nov 2019
    AU
    I’ve got it too. It’s the eBrake that needs adjusting.
    Had it done at a workshop and it came back though..
    Apr 2012
    Whyalla, SA
    Quote Originally Posted by DWU View Post
    Completely different occurrence and sound.
    I do agree that regular servicing of the EPB is a good thing though Low Speed Squeal- Brakes
    Jul 2012
    Thanks, but it's not the EPB. Unrelated to this problem, I adjusted the EPB last weekend.
    St Helena,Melbourne
    1.13 MB
    I also get a small squeal just in the last 1m of braking at very low speed, most likely just pad material.
    I put TRW pads on and they were supposed to be the ceramic versions but are actually a silica compound and chewed the rotor in less than 20k so will be up for new rotors when these rocks wear down instead of just the pads.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Mar 2016
    I went the Akebono and haven’t looked back having used many types
    2007 Audi RS4 (B7)
    Sep 2014
    Baldivis WA
    +1000 for Akebonos.
    Squeal could be embedded pad material in the pad face itself. Had the same on my wife's Jeep. Took the pads out and filed the surface, squeal all gone.
    Edit: just to clarify, it was a piece of sintered material about the size of a grain of rice. I noticed the rotor was getting a bright strip on it, same one as the 'squeally' corner. These are factory mopar pads with 57000km on them. Also no dust and very nice braking performance.
    Jul 2012
    Quote Originally Posted by Eric SDV6SE View Post
    +1000 for Akebonos.
    Interesting, will give it a try. Thanks!
