Results 1 to 4 of 4
Thread: Gap Tool faults
    May 2003
    On The Road
    Gap Tool faults
    Found these,,
    any show stoppers?
    VIN SALWA2JE8GA597991
    Model L494 - Range Rover Sport 2016
    Vehicle scanned on 17 Aug 2021 10:41:06 am
    IIDControl 3.0.0 Build 84 Android - IIDTool BT V4.0 B2742
    BCM-Body Control
    B10A2-38 (28) Crash input - Frequency modulation/pulse width modulation failure - signal frequency is incorrect
    ( on 16-08-2021 10:58:19 at 70125 km )
    GSM-Gear Shift
    U0422-00 (28) Invalid data received from the body control module
    ( on 03-08-2021 09:24:00 )
    HVAC-Ventilation
    B103F-87 (28) Rear seat heater control - Bus signal/message failure - missing a message
    ( on 11-08-2021 10:02:07 at 69969 km )
    B1352-97 (28) Front left - Temperature damper motor - Component failure - component or system operation obstructed or blocked
    ( on 11-08-2021 14:05:53 at 69969 km )
    SODL-Left Side Object
    U0010-87 (28) Medium speed CAN communication bus - Bus signal/message failure - missing a message
    ( on 11-08-2021 10:02:02 at 69969 km )
    SODR-Right Side Object
    Dec 2009
    Ranelagh, Tasmania
    Found these,,
    any show stoppers?
    BCM-Body Control
    GSM-Gear Shift
    HVAC-Ventilation
    None that I can see, clear them and see if they return or anything doesn't work. I suspect a lowish battery and starting will trigger the comms errors.
    Fuji white RRS L494 AB Gone
    2023 Ford Ranga
    May 2003
    On The Road
    Hmm, well it has driven around town for 2-3 weeks, maybe the odd 3 minute motorway run thrown in, Gap Tool faults its had two one hour runs in the last two days,, but now gets to sit in a workshop for 6 days.....
    Yass NSW
    Mine does throw some errors occasionally and I just clear them when they happen. Canbus errors seem to be a feature and looking at it from a systems diagnostic viewpoint I suspect the reporting level is turned up too high. Unless it is a recurring error that is directly traceable to a hardware fault I would not investigate further. Mine has a failure on the humidity sensor on the windscreen which I will replace one day when I have a few hundred dollars to waste and also throws errors relating to the DRL on the passengers side which flickers sometimes and which I suspect may be related to a bad earth.
    Bearing in mind that LR don't expect end users to be accessing fault codes except when they escalate to a light on the display and that interpretation and evaluation of logged errors is usually done with staff trained to assess the seriousness and relevance of the errors.
    Regards,
    Tote
