Results 1 to 10 of 18
Thread: Brake temp issues when towing
    May 2003
    On The Road
    This thread was split out from another. Please read further down to get the gist of the issue.
    Both items work fine....
    The car however.....
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    BPL ?
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    May 2003
    On The Road
    Dunno what to say,, had wifts of smells at home sometimes, then first time with the van slowing to a roundabout from the highway, then 10 secs later to a dump spot, get yelled at by Di in the navigators seat "theres smoke coming out"
    front left was pretty hot.. much more than the right,
    no pulling, no vibes. RACQ wouldnt even jack the wheel up..
    Luckily our Yandina campsite was only 5 kays away, though when we got there the RIGHT side was hotter than the left????
    Coming back through Maroochydore this morning got a single brake squeal but both sides were cool when we parked??
    Jan 2016
    Tolga FNQ
    Bearings or brake pads?
    May 2003
    On The Road
    Land Rover Tech says all wonderful, bearings, pads, discs,
    There was a TSB issued for squeaks on Brembos, add slide lube basically.
    The Tech says to rekit both calipers.
    which would fix that problem,,,
    if my problem is THAT problem..
    https://static.nhtsa.gov/odi/tsbs/20...06443-9340.pdf
    Jan 2016
    Tolga FNQ
    I hope that’s just it mate, and sounds about right as smoke from the front ends just sounds so un natural, and no reason for it apart from something being over tightened or dry.
    Here’s hoping.👍
    Dec 2011
    Bundeena
    Have you verified your brake controller is working properly?
    Sean
    May 2003
    On The Road
    Shouldn't matter, the D2 did the same manuver many times without van brakes and nothing bad happened. Both fronts should be equally hot,,
    Any bit the bullet and towed to our second favourite spot, Kandanga, and yes, front left was a lot hotter than the right( which was only warm.. )
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    in my limited experience
    there is always one electric brake that is hotter than the others
    and it is nearly always on the left side....
    just been my experience
    what size is the brake wiring to the plug on the vehicle ?
    NSW SW Slopes
    Is the van doing the braking for the car too?
