The ignition switch, as you may have noticed, is a lot beefier than the one on petrol Landrovers of similar vintage (always assuming it is original), and seeing it was designed to handle the glowplug load and has presumably done so for over fifty years, I would not see a good reason for fitting a relay. On the other hand, if you have had to replace the switch with a non-standard one, that relay would look to be quite suitable.
