Results 1 to 10 of 13
Thread: Borescope Camera - DIY Hi-Temp Version
    Apr 2019
    the only off the shelf unit to suit our application is worth $125,000, from memory this one will handle 1500 degrees.
    I did find a unit overseas that can handle 300 degrees for a short period of time, 200 degrees for longer time
    Problem is I need one to handle 850 degrees for maybe 10sec max.
    Sooo DIY it is…….what my chances of success.??
    I am aware of a company in the west that uses go-pro’s is a custom made insulated box, they have worked out max time it can be in the environment so they can still read the SD card . The go pro is single use, as it’s destroyed in the process of taking the videos.
    I’ll plough ahead to a bore scope……..as we want to see what it’s looking at in real time. I have a few ideas up my sleeve…..
    Be interested in members thoughts on how they would approach this build!!!!!
    Mar 2018
    What do you actually need to look at ?
    BradC is online now Super Moderator
    No one of consequence
    Supporter
    Mar 2018
    Perth (near Malaga)
    And how big is the hole?
    Apr 2019
    Quote Originally Posted by speleomike View Post
    We need to check two cross overs in a vertical shaft kiln for build dust which may jab turned into lump.
    The next problem will be how do we remove it. Previous designs had air cannons however the manufacturer has moved away from this due to issues the cannon cause.
    Apr 2019
    Quote Originally Posted by BradC View Post
    The access hole is 232mm x 232mm square x 1000mm deep/long.
    The cross overs are maybe 1400 x 800 and arched at the top.
    Supporter
    Mar 2018
    Perth (near Malaga)
    My initial gut idea was something like a conventional borescope inside a stainless tube with a quartz window and some dense insulation like fibreglass between the borescope and the stainless wall. Trying to use the thermal inertia and poor conductivity of the stainless coupled with the insulation to keep the actual borescope cooler.
    Kinda like a thick insulating condom.
    Apr 2019
    Your thoughts are very much aligned with mine.
    I’m thinking off running a thermal couple next to the camera cable so we can monitor temps at the camera
    Also considering running ambient air through the pipe….to take heat away.
    Supporter
    Mar 2018
    Perth (near Malaga)
    10 seconds isn't a lot of time, you'd need to make sure the thermal inertia in the thermocouple was small enough to get an accurate reading.
    The other thing I thought was using a big enough bit of tube, space the borescope internally with a spider and run a small pipe down the inside to push compressed air into the lens end of the tube to help carry the heat back up the tube.
    Sep 2013
    Darwin
    12.74 MB
    Quote Originally Posted by W&KO View Post
    Interesting project. I have a small hobby waste oil furnace, so always interested in furnace stuff.
    Sapphire lens higher melt temp. I got several 3 inch dia by 1 inch thick, used, from USA for a few hundred - a nice big window - if you're customising then diamond tooling required (lapidary saw and laps/grinders). Someone will sell something ready made for your size requirements more expense. You melting aluminium? Wonder if there could be a flux effect on sapphire, aluminium oxide? Note I'm not using my sapphire for furnace related matters.
    Iced water jacket/coils like convection furnace.
    How close have you got to get to the site of interest. Remote port hole with telescopic camera lense set up?
    Was involved years ago with building a borescope that could survive insertion into a blast furnace ~2000C +.
    Inconel 600 series alloy tube, think we had a sapphire window, optic fibre and **** loads of water cooling. Worked fine till someone forgot to turn the water cooling on one day.
    2024 RRS on the road
    2011 D4 3.0 in the drive way
    1999 D2 V8, in heaven
    1984 RRC, in hell
